Allis Chalmers 185
PaulSamwel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 185
    Posted: 01 Mar 2026 at 7:45pm
Bought this non running tractor for not much.Got it running(fuel system issues),replaced front and rear tires,replaced oils and filters,installed a block heater,new starter,went through battery cables,repaired short in lighting system,repaired non working gauges.Repaired front axle from loader abuse.Has 1579 hours on a working meter.Used mainly for loader work as rest of tractor shows very little wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2026 at 7:48pm
Looks like I can make the pictures larger.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 5:22am
Nice!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 5:48am
Ya can't go wrong with a 185! Very sweet tractor
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 9:20am
My only concern would be gear jumping with full time loader use. Lot of shifting back and forth. All depends on operator. My uncle bought a new 185 back when. Got to run it on a rotary hoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 12:08pm
This is my first A/C tractor,this one was built in 1980.Am concerned about that as well from what Iv'e been reading about these tractors.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 12:22pm
I would say to get used to using the power director before you start using it for hay work (assumption on my part, the tedder is in the background). I use a 190xt mainly, also have a 7000 and a 4430JD. I prefer the 190xt, and I think you will like your 185.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 12:25pm
If you got that for cheap that’s a nice one!! They are nice tractors, hopefully the previous owner brought the tractor to a complete stop before shifting. Low hours if they are correct. Rops is a nice option to have.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 3:15pm
Can't see how the front axle would need repair after only 1500 hours of use - even with a loader.  Tack could have been replaced, drive cable could have been broken for years (or unhooked).  I never trust the hours on these older tractors.  The tach on my 175 shows around 5000 hours, but the tach cable was disconnected for 15 years!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 8:28pm
 Read the pedals and drawbar hole.....
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 12:36am
One comment I wanted to make is on the aftermarket nose latch. One of the members here has reworked his 190XT if I remember correctly by welding tabs on the inside of the nose and putting bolts through the side panel. There are pictures and some comments on it, maybe even a separate thread. I tried to find it to do a link, but was unable. Maybe someone else can find it. It looks like an easy modification, I may try it on one of mine soon.
Ted
DanWi View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 10:02am
For the grill I use about a 1in x 3in x 1/4 strap metal. Drill a hole on each end and weld a nut, I used 1/4 on one set I made and 3/8 on another. If you used thicker steel, you could just tap threads. Then go in the area by the latch maybe just above or below and drill holes thru the side plate and grill that line up with your plate. Then using painted bolts or stainless or whatever you choose, bolt the plate inside the side tin and then put the grill on and put the other bolt in. The only thing you will see on the outside is 2 bolt heads.
