Allis Chalmers 185
PaulSamwel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 185
    Posted: 18 hours 40 minutes ago at 7:45pm
Bought this non running tractor for not much.Got it running(fuel system issues),replaced front and rear tires,replaced oils and filters,installed a block heater,new starter,went through battery cables,repaired short in lighting system,repaired non working gauges.Repaired front axle from loader abuse.Has 1579 hours on a working meter.Used mainly for loader work as rest of tractor shows very little wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 37 minutes ago at 7:48pm
Looks like I can make the pictures larger.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 3 minutes ago at 5:22am
Nice!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 37 minutes ago at 5:48am
Ya can't go wrong with a 185! Very sweet tractor
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 5 minutes ago at 9:20am
My only concern would be gear jumping with full time loader use. Lot of shifting back and forth. All depends on operator. My uncle bought a new 185 back when. Got to run it on a rotary hoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 17 minutes ago at 12:08pm
This is my first A/C tractor,this one was built in 1980.Am concerned about that as well from what Iv'e been reading about these tractors.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 3 minutes ago at 12:22pm
I would say to get used to using the power director before you start using it for hay work (assumption on my part, the tedder is in the background). I use a 190xt mainly, also have a 7000 and a 4430JD. I prefer the 190xt, and I think you will like your 185.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 60 minutes ago at 12:25pm
If you got that for cheap that’s a nice one!! They are nice tractors, hopefully the previous owner brought the tractor to a complete stop before shifting. Low hours if they are correct. Rops is a nice option to have.
