allis chalmers 160 clutch
flem1951 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers 160 clutch
    Posted: 03 Aug 2023 at 12:36pm
greetings,
transmission will not engage. I have the pedal adjusted to the proper setting.  I broke the tracker and checked the clutch assembly, all in excellent condition. I can turn the tractor off, engage the tranny and engage the clutch and it move just fine. try to engage the trany when engine is running and all i get is grinding gears. is it possible the clutch pedal is not shjaft assembly?
   any ideas out there?
thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2023 at 12:37pm
I ment to say that is it possible that the pedal is not posstioned on the shaft assembly correctly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2023 at 9:08pm
I believe you have the shims facing the wrong way. You should have 3 shims under each bolt. The flat spot on the shims faces outward. I made a mistake and faced them inward, it took me awhile to realize my mistake. The shims facing the wrong way will not let the clutch release or disengage properly. The flat side will catch the edge of the clutch disk. Faced them outward and all is well.
Edited by AC720Man - 03 Aug 2023 at 9:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2023 at 9:24pm
If you have the tractor back together, look up through access hole at the bell housing with a flashlight. With the tractor in neutral, have someone turn the engine with a socket on the crank. As the flywheel comes around to the shims, make sure the flat side is facing outward on all 3 shims under each bolt.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 3:21am
Check out what Rob mentioned to you there...if they're right, then I think the clutch disc is bent or in backwards...check the shims first though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 3:31am
Pilot bearing dry and dragging ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 7:50am
Is this happening after a new clutch install? That’s why I mentioned the shims. Did you just split the tractor and look at it or was any disassembly done? DR Allis made a good point to also check the pilot bearing. I should have asked more questions, just assumed a new clutch install.
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 3:42pm
just split the tractor and removed the clutch and the clutch assembly. clutch plate is is good. has the appropriate shims, had the clutch assembly looked at and is in working order. throw-out bearing is good. must be something in the trany.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 9:31pm
Dan, I read through your post again. You asked if the clutch pedal was on the shaft correctly? Unless it has been removed for some reason I see no reason for it not to be correct. After all, I’m confident it worked before so something else must be wrong. Some more information, background on how the tractor started acting this would be of great help.
This page was generated in 0.045 seconds.
