Allis Chalmers 15-25 Restoration
 Post Reply Post Reply Page  <123>
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 9:49pm
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 9:54am
   Atta boy Jacob!!!  You have a knack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 9:57pm
We've been busy hauling home more toys.  Check out what I found, or rather what found me!
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2022 at 1:16pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 9:18pm
I think we have reached the "hump" in the project, things are mostly all apart and starting to go back together.
Check out this weeks episode, part 23:
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 7:49pm
We got the babbitt scraped in, thanks for all the suggestions.
Here is part 24:
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2022 at 8:06pm
Jacob Swanson
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2022 at 10:14pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2022 at 9:42pm
Here is a long overdue part 27.  Fall is right around the corner, and I hope that will bring more tractor time with it.
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2022 at 9:16pm
Little progress with part 28:
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2022 at 8:08pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2022 at 7:24pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2022 at 10:04am
Here is part 32:
I recorded this video in a different aspect ratio than usual. See the pinned comment on YouTube for details.
Do me a favor and leave a comment on the video about what you think, thanks!
Jacob Swanson
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 9:19pm
Jacob Swanson
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2022 at 10:20am
Jacob. those small pieces of cast iron shrapnel may be chips from the internal teeth on those cast iron drive hubs.  If the ones you have are perfect, then they may be from a previous set of hubs that were replaced due to excessive wear.  I know of several 20-35's that had them replaced over the years including one of my own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 10:05am
Phil, yes that is the best explanation I have for the shrapnel as well.  I have yet to fully clean up the final drives, so there is a chance there is a few chips out that I haven't noticed, time will tell...
Edited by Jacob (WI,ND) - 31 Dec 2022 at 10:06am
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 10:17am
Jacob Swanson
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 12:10pm
Jacob,
Take a look at standard EMT tubing for the sparkplug wire tube.
Although the wall thickness might be a bit thin compared to the original, 1" EMT might do the trick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2023 at 12:58pm
Originally posted by Gatz in NE Gatz in NE wrote:
Jacob,
Gatz,
That is exactly what I ended up going with.  I have the piece of conduit on hand, just need to figure out how to bell the ends, and cut some holes.  You'll be seeing that in a few weeks, that is the downside/upside to getting a bunch done over Christmas break, I have a few weeks backlog of videos waiting to be released, so I am a bit "ahead" of what you guys are seeing.  Thanks!  Appreciate all the comments!
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 1:34pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 9:54pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2023 at 1:29pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 1:18pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2023 at 11:31am
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 10:01am
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2023 at 8:31pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 9:13am
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 11:03am
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2023 at 11:55am
Interesting collection of videos.
To answer your question in this last video on the bars. They are torsion bars in some front ends of cars an trucks. It’s the front suspension. Fits into the front like A arms then goes back under and fits in these keys that has adjustment. Basically twists that bar to act like front springs
Edited by Mikez - 11 Mar 2023 at 11:55am
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 9:43pm
Thanks for that info Mike, torsion bars seems to be the answer, I have gotten several comments and texts from people after that video was released stating that is what they are for.  That is what is nice about YouTube, there will be someone who knows if you don't.  Thanks!
Here is Part 46:
Jacob Swanson
This page was generated in 0.110 seconds.
