allis chalmer wd40 |
rhesamc
Joined: 28 Oct 2014 Location: Bridgeport NY Points: 8 |
Topic: allis chalmer wd40Posted: 19 Jul 2025 at 7:43pm |
I cannot find a timing mark on the flywheel. I don't seem to see an inspection plate either.. I took the plate at the bottom of the flywheel off and rotated engine, but I cannot find a timing mark. I assume I am doing something wrong. Please somebody help me. Rhesa McKnight
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4271 |
Posted: 20 Jul 2025 at 4:44am |
They are there, you may need to wipe the flywheel clean with some brake-clean and a rag to see them.
Posted: 20 Jul 2025 at 7:14am |
This is easy on a WD-45. Remove the clutch housing cover complete from underneath the flywheel. Rotate the engine until the crankshaft pulley setscrew is pointed exactly straight down. If you do this, the TDC Mark will be right there on the bottom edge of the flywheel. It's probably covered in rust and will need cleaning. There are two marks: TDC and "F" or "FIRE" which is 30 degrees BTDC. A properly timed engine is the FIRE Mark at wide open throttle.
Joined: 11 Sep 2009 Location: illinois Points: 90653 |
Posted: 20 Jul 2025 at 7:44am |
wire brush or 100 grit sandpaper and good ways to cleanup the area..
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8973 |
Posted: 20 Jul 2025 at 1:49pm |
Even cleaned up they are hard to see. Mark the FIRE line with white paint or something so it's visable when viewing with timing light. If it has M&W's it might be closer to 25Deg advanced. They were higher compression and detonate at 30.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1333 |
Posted: 24 Jul 2025 at 5:18pm |
Hmm, I wonder if I put my wd fly wheel back on right?
Didn’t know there was any marks on the fly wheel when I put rear crank seal in…. Is there 3 ways the fly wheel will go on wrong? |
Posted: 24 Jul 2025 at 6:05pm |
Flywheel only goes on one-way.
Walker
Posted: 24 Jul 2025 at 6:22pm |
If you are looking under WD 40 it's easy to understand how you may have gotten inaccurate information. Best and most sure way to find a timing mark is remove one plug, replace wire and hand it to your wife while saying hold this, turn ignition on and rotate flywheel until you find it or notice some other indicator you are close.
Edited by Walker - 24 Jul 2025 at 6:36pm |
