Allis CA
 Post Reply Post Reply Page  <1 161718
 Rating: Topic Rating: 4 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:41am
Mike, Folks,
 A little more of that too! I did leave the dash box in the lower position. I couldn't get the 5/16 nut on the back of the box. The Battery box bracket was in the way.
Remember this is only a Clean, Refurb, and Paint project. I have had the gas tank assembly on and off several times. I forgot I needed to run the wires in the tool box area.
Headlights and tail light wiring is what's left to complete.
Edited by Sugarmaker - Yesterday at 12:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 54 minutes ago at 8:38pm
Guys,
Almost there!
Tonight I completed the spark plug wires. Primed the oil pump. Got a new battery from Walmart. The old battery had been used on my electrolysis tank and it is pretty hard on them. It would spin the tractor and then die. Took a couple tests to determine it was not good under load. Oil pressure is at the N in normal with our running yet. Just cranking.
I tried the hood. Looks like it will be ok when finally fit.
Busy day tomorrow but may try to start the CA? Cheryl's birthday is Tuesday. I would like to have it running. I did try the lights and they worked.
Some other shots:
I know the cable colors are not correct. But that is what NAPA had.
Luan cover to keep lid off the terminals
The silver bullet
Cheryl helping prime the oil pump. Crude set up but it worked!
 Chris and Cheryl
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 18 minutes ago at 9:14pm
Man, that looks great.Nice work!
This page was generated in 0.049 seconds.
