Allis CA
 Post Reply Post Reply Page  <1 91011
 Rating: Topic Rating: 4 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 2:45pm
I'd mike the paper, and then (for example) Google .010 gasket paper, get a roll and cut it out myself.  They are easy enough, tape a slightly bigger piece of paper than you need to the pump, take a ball peen hammer and tap lightly around the edges, and at the bolt holes, and the paper is marked for cutting...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 3:48pm
the gasket should be as thin as possible without having the rotor drag the cover.. It might be 3-4 thousands.. You can put a straight edge across the case and measure the rotor depth with a feeler gauge.. .... if you use permatex you want a VERY THIN see thru layer on the gasket... normally you can soak the gasket in oil and Squeeze it  with the cover..
a piece of construction paper or note book paper might the the right thickness.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 3:51pm
Dave,
 Yes, I have done that with several gaskets in the past. Getting lazy.
But now would be the time to do it over. Story of my life.
Thanks for the input.
 Chris and Cheryl
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 7:24pm
I smeared a very, very thin coating (like Steve said) on the pumps for my WD. Yes, plural... I rebuilt the original pump and then lucked into a much nicer shape AGCO retrofitted version so I went through it too before putting it back together. I used an old school shellac after flattening the bottom plate as much as I could with glass and a sheet of sandpaper.
Disclaimer... it's not running yet, ha. You're still way farther ahead of me on this CA than I am on my WD that keeps falling to the backburner. And I have a CA project that needs to go into the shop sooner rather than later. I can't wait to see your tractor back in tip top shape!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 7:56pm
Guys,
 Thanks for the ideas and support on the CA oil pump. I mean it is the heart of the system. I am great for doing things twice, or maybe even three times! So I may pull it off and clean it up again and start over I also got some good advice from a CA expert. That's what I like about this forum. Great suggestions, and recommendations! I should ask before I act. But that's not like me. More like the bull in the China shop!
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2024 at 6:35pm
Allis folks,
 So I took the CA oil pump back off. Several things to improve/ redo. First I forgot to put the gasket from block to the pump. Found the gasket in with the others in the gasket kit. Oops!
Second I took the pump back apart and cleaned the mating surfaces. I reversed the vanes in the pump. I was told this may improve the oil pressure a little. All for that, and the vanes seem very happy reversed.
Cleaned the outside cover plate. Very little wear on the plate. I suppose I could try to get those shallow grooves out of it?
Was warned that Allis may have made a small and large oil pump. Well the gasket I have does not fit well, so maybe the pump I have is a big pump? Have to measure the gasket thickness and maybe carve one out of a sheet. Unless there is a large pump gasket out there?
I did get the dial indicator to play with at some point too. Maybe use it to reset the valve clearance more accurately?
Merry Christmas to all forum members and their families!
 Chris and Cheryl
Edited by Sugarmaker - 22 Dec 2024 at 6:50pm
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2024 at 10:40am
Merry to You & Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 10:46am
Allis folks,
Our son Adam found a gasket on line that says its for a D10, D12 ..... It looks larger in the picture so we ordered one. We will see next week when it gets here.
Here is the common paper gasket that I made. It doesn't look too bad.
Rear wheel assemblies got some attention. Disassembly, then planning to clean and paint.
These are not Allis rims as you have noted. IH style centers. and weights chopped up to match.
So if the weather is warm enough I plan to put these centers in the E-tank, and wire brush the rims. Rims have been widened in the past. The tires have some age but should work just fine for a little puller in the stock classes.
Happy New Year!
 Chris and Cheryl
Edited by Sugarmaker - 31 Dec 2024 at 10:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 3:09pm
Happy New Years . Been reading your postings in the Ford barn I am still a couple years back. Keep up the good work
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 3:59pm
Just a comment, we have been finding many camshaft oil pump drive pins loose in the bore. We always check on cam driven oil pumps B-G160 D15II. A loose drive pin will dump oil pressure at the back of the cam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 8:59pm
tadams and tbran'
The Ford barn is a lot of fun for us. Trying to keep the Fords running along with these Allis tractors too! If you cant sleep, reading some of my posts there could help.
Thanks for the hints on the pin in the pump. Of course I did not check that! :) Humm?
(update) i guess I should ask more about how you check that and fix it if out of spec?
 Chris and Cheryl
Edited by Sugarmaker - 01 Jan 2025 at 10:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 6:53pm
Allis guys,
 I got a start on cleaning the rear rims on the CA. The tires have some cracks for sure but should be ok for pulling for a while. The plan is to paint the rims a silver color. Maybe Rustoleum rattle can silver. Not sure on the center portion of the wheel color? Maybe the off white. Then I have to paint the partials of the weights also. The weights could be off white also. I have a plan to set up a temp paint booth in the shop. Crude but should help control most of the over spray. The Comet and the 32 have covers on them.
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 7:28pm
Chris, I sure hate to see anything other than power adjust rims on a CA, but I'd reuse them too in your situation. You don't need tread adjustment for cultivating. New rims aren't cheap!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 7:37pm
I have painted several rims with this.... I just use a brush, not spray..
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 8:38pm
I've painted guitars with that hammered rustoleum, spray rattle cans though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 9:40pm
Guys,
 Thanks for the suggestions! The answer is in there somewhere!
Welcome to 2025!
 Chris and Cheryl
