Allis CA |
Post Reply | Page <1 8910 |
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3478 |
Thats the one I got. A YT video suggested Pine Sol and water. One bottle and the balance in water was less than 50/50. One must be cautious that cleaning solvent is compatible with the parts being cleaned
jvin248
Silver Level Joined: 17 Jan 2022 Location: Detroit Points: 323 |
. 50/50 ultrasonic mixes seem excessive. Water does the work, the soap and degreasers just lift the oils so the water gets in. Soap breaks oil surface tension. I only use the soap cleaners like doing dishes. There might be a perfect ratio in between though. .
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1549 |
Your engine side weights aren’t actually for a CA. You have B and C weights but I think they will work.
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8295 |
Sparky,
Thanks! Why does that not surprise me? Everything else on the CA has been miss matched and thrown together. I did search for some CA weights and see that they are a different shape too. Am I right about the knob needing to come out and I need to find another knob for the other side. Another small project! So the continuing saga of the crusty old CA: I set the rocker arm assembly on the head tonight. As I was seating it I found that the # 2 riser/support was cracked on the top through the stud hole. Going to see If I can find a good used one. I have to relearn about the initial valve setting again. I think I am losing it, or maybe it was already gone!:) As I reviewed the oil filter base, I found a crack in that too. I think this old girl is playing all her cards and really is one of those tractors that needs a lot of attention! Maybe just Ms Needy? Just small moves like cleaning nuts and bolts, Buying several hundred dollars worth of parts every few days to satisfy my orange habit! And hoping a lot! Looking forward to painting some parts if the weather warms to 60F again soon. Lots of prep to do! Nice that this is the only project in the shop right now too. Lost about two weeks here with both of us having head colds. I do need to go look at those other two CA's up near the lake in Grape country also! I also need to talk with Steve at B&B about maybe making a wiring harness for this tractor. I think he might be able to do it??:) Regards, Chris and Cheryl
Edited by Sugarmaker - 21 Nov 2024 at 9:13pm |
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4926 |
Mixture in the ultrasonic cleaner depends on what your trying to clean. In my case it was years of grease and dirt. Lower amount of super clean/water for easier clean up. I completely rinse after its clean. The amount of crud it got of was pretty amazing.
Chris, our CA weights has a bushing and bolt that holds it in place. I will take a picture of our weights if you would like?
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4753 |
When you have a C front bolster/support instead of the correct CA casting, only the B/C side weights will work.
I'll again offer the correct CA bolster/Steering support for free if you come get it, as I first did when you got into this project. I'll now also offer to trade your B/C weights for a correct pair of CA side weights with the mounting hardware, however no shipping. I've always used a long bolt with about 3 lockwashers then a nut drawn up to the head as the front mount for those weights.
Sugarmaker
Paul,
Thank you for the generous offer. I believe I will stay with my Frankenstein front end and weight system assuming it will all go together!:) Regards, Chris and Cheryl
Edited by Sugarmaker - 22 Nov 2024 at 7:52pm |
Sugarmaker
Allis folks,
The saga of the CA continues. I took the support out of the rocker arm assembly and barely tweeked the part. A good used one is one its way from Brenda at Sandy Lake. She is looking for a better oil filter base too. We worked on the B/C weights and some heat and air hammer work removed the support plug and bolt. Most of the hardware is cleaned and ready for paint. We continue to move forward. Next big items may be the rims. Regards, Chris and Cheryl
jvin248
. You got the "one horse shay" of tractors. It was barely holding on. .
Phil48ACWC
Silver Level Joined: 17 Jan 2013 Location: Vermont Points: 289 |
I have a good oil filter base with stand pipe. I also have rocker shaft pedestals from a WC. Not positive if the pedestal is same as yours. I could measure it, if you're interested. $50 plus shipping.
Edited by Phil48ACWC - 23 Nov 2024 at 8:39am |
wjohn
Orange Level Joined: 19 Jan 2010 Location: KS Points: 1998 |
I run into those broken supports in about every other AC engine I work on, it seems. I'm sure someone overtorqued the nuts in the past and it splits them right down the middle like that.
Sugarmaker
jvin248,
I had to Google the one horse shay concept. I see its when it falls apart all at once. Yes about like this old CA! Phil, Thanks I have a used support on its way. Maybe the oil filter piece also. Sandy lake has some spares tucked away also. Thanks for the support and offer. That could have easily been overlooked and not been good for the engine/ valve system. John, If I ever do another one I will check that. Spent the afternoon in the rain and wind helping the three man crew working on my grandsons new shop. Putting up steel on the west side. A good day for me to get out and do something even if it is holding the dumb end of a tape measure. Regards, Chris and Cheryl
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 81302 |
Chris... you might end up famous !
-------- the "one piece at a time" carThe one piece at a time' Cadillac made famous by the Johnny Cash The transmission was a '53 And the motor turned out to be a '73 And when we tried to put in the bolts all the holes were gone So we drilled it out so that it would fit And with a little bit of help with an adapter kit We had that engine runnin' just like a song Now the headlight' was another sight We had two on the left and one on the right But when we pulled out the switch all three of 'em come on The back end looked kinda funny too But we put it together and when we got through Well, that's when we noticed that we only had one tail-fin About that time my wife walked out And I could see in her eyes that she had her doubts But she opened the door and said, "Honey, take me for a spin" Edited by steve(ill) - 23 Nov 2024 at 7:38pm |
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 51722 |
Did I hear a request?
Sugarmaker
That would be great if you had the time to post a picture of your weight set up. A l;little thing but I just had not been around these side weights before. And the mis match of many Allis parts is interesting. I probably need to look at a ultrasonic cleaner for the shop too! Regards, Chris and Cheryl
Sugarmaker
Allis folks,
I did get the support for the rocker arm shaft. I thing this is a perfect fit for this little Frankenstein puller! Way better than the split "high performance" version that we will set aside as another learning experience on the CA project. Hope things are good and safe travels to those on the road for Thanksgiving! Regards, Chris and Cheryl
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3741 |
Chris, I've seen Allis rocker-stands like that brazed back together. Must have been somewhat common.
