Allis CA
 Post Reply Post Reply Page  <1 8910
 Rating: Topic Rating: 4 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 6:06am
Thats the one I got. A YT video suggested Pine Sol and water. One bottle and the balance in water was less than 50/50. One must be cautious that cleaning solvent is compatible with the parts being cleaned
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 10:08am
50/50 ultrasonic mixes seem excessive.
Water does the work, the soap and degreasers just lift the oils so the water gets in. Soap breaks oil surface tension.
I only use the soap cleaners like doing dishes.
There might be a perfect ratio in between though.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 10:32am
Your engine side weights aren’t actually for a CA. You have B and C weights but I think they will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 8:55pm
Sparky,
Thanks! Why does that not surprise me? Everything else on the CA has been miss matched and thrown together. I did search for some CA weights and see that they are a different shape too. Am I right about the knob needing to come out and I need to find another knob for the other side. Another small project!
So the continuing saga of the crusty old CA:
I set the rocker arm assembly on the head tonight.
As I was seating it I found that the # 2 riser/support was cracked on the top through the stud hole.
Going to see If I can find a good used one. I have to relearn about the initial valve setting again. I think I am losing it, or maybe it was already gone!:)
As I reviewed the oil filter base, I found a crack in that too.
 I think this old girl is playing all her cards and really is one of those tractors that needs a lot of attention! Maybe just Ms Needy?
Just small moves like cleaning nuts and bolts, Buying several hundred dollars worth of parts every few days to satisfy my orange habit! And hoping a lot!
 Looking forward to painting some parts if the weather warms to 60F again soon. Lots of prep to do! Nice that this is the only project in the shop right now too.
Lost about two weeks here with both of us having head colds.
I do need to go look at those other two CA's up near the lake in Grape country also!
I also need to talk with Steve at B&B about maybe making a wiring harness for this tractor. I think he might be able to do it??:)
 Chris and Cheryl
Edited by Sugarmaker - 21 Nov 2024 at 9:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 10:53pm
Mixture in the ultrasonic cleaner depends on what your trying to clean. In my case it was years of grease and dirt. Lower amount of super clean/water for easier clean up. I completely rinse after its clean. The amount of crud it got of was pretty amazing.
Chris, our CA weights has a bushing and bolt that holds it in place. I will take a picture of our weights if you  would like?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2024 at 6:35am
When you have a C front bolster/support instead of the correct CA casting, only the B/C side weights will work.
  I'll again offer the correct CA bolster/Steering support for free if you come get it, as I first did when you got into this project. I'll now also offer to trade your B/C weights for a correct pair of CA side weights with the mounting hardware, however no shipping. I've always used a long bolt with about 3 lockwashers then a nut drawn up to the head as the front mount for those weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2024 at 8:21am
Paul,
Thank you for the generous offer. I believe I will stay with my Frankenstein front end and weight system assuming it will all go together!:)
 Chris and Cheryl
Edited by Sugarmaker - 22 Nov 2024 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2024 at 8:07pm
Allis folks,
The saga of the CA continues. I took the support out of the rocker arm assembly and barely tweeked the part.
A good used one is one its way from Brenda at Sandy Lake.
She is looking for a better oil filter base too.
We worked on the B/C weights and some heat and air hammer work removed the support plug and bolt.
Most of the hardware is cleaned and ready for paint. We continue to move forward. Next big items may be the rims.
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2024 at 11:25pm
You got the "one horse shay" of tractors.
It was barely holding on.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2024 at 8:38am
I have a good oil filter base with stand pipe. I also have rocker shaft pedestals from a WC. Not positive if the pedestal is same as yours. I could measure it, if you're interested. $50 plus shipping.
Edited by Phil48ACWC - 23 Nov 2024 at 8:39am
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2024 at 9:13am
I run into those broken supports in about every other AC engine I work on, it seems. I'm sure someone overtorqued the nuts in the past and it splits them right down the middle like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2024 at 4:44pm
jvin248,
I had to Google the one horse shay concept. I see its when it falls apart all at once. Yes about like this old CA!
Phil,
Thanks I have a used support on its way. Maybe the oil filter piece also. Sandy lake has some spares tucked away also. Thanks for the support and offer.
That could have easily been overlooked and not been good for the engine/ valve system.
John,
If I ever do another one I will check that.
Spent the afternoon in the rain and wind helping the three man crew working on my grandsons new shop. Putting up steel on the west side. A good day for me to get out and do something even if it is holding the dumb end of a tape measure.
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2024 at 7:34pm
Chris... you might end up famous !
the "one piece at a time" car
The one piece at a time' Cadillac made famous by the Johnny Cash
The transmission was a '53
And the motor turned out to be a '73
And when we tried to put in the bolts all the holes were gone
So we drilled it out so that it would fit
And with a little bit of help with an adapter kit
We had that engine runnin' just like a song
Now the headlight' was another sight
We had two on the left and one on the right
But when we pulled out the switch all three of 'em come on
The back end looked kinda funny too
But we put it together and when we got through
Well, that's when we noticed that we only had one tail-fin
About that time my wife walked out
And I could see in her eyes that she had her doubts
But she opened the door and said, "Honey, take me for a spin"
Edited by steve(ill) - 23 Nov 2024 at 7:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2024 at 8:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2024 at 11:43pm
That would be great if you had the time to post a picture of your weight set up. A l;little thing but I just had not been around these side weights before. And the mis match of many Allis parts is interesting.
I probably need to look at a ultrasonic cleaner for the shop too!
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 46 minutes ago at 8:30pm
Allis folks,
I did get the support for the rocker arm shaft. I thing this is a perfect fit for this little Frankenstein puller!
Way better than the split "high performance" version that we will set aside as another learning experience on the CA project.
Hope things are good and safe travels to those on the road for Thanksgiving!
 Chris and Cheryl
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 48 minutes ago at 8:28am
Chris, I've seen Allis rocker-stands like that brazed back together. Must have been somewhat common.
