Allis C
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: Allis C
    Posted: 25 May 2019 at 9:17pm
Is the torque tube longer on a C Allis than on a B ?
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2019 at 10:50pm
IAW parts book, B and C torque tubes are interchangeable.  The IB has its own part number
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 7:10am
If you need one I have ten
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 7:24am
10! Holy Moly Lon, I have two and thought that was a lot!  LOL!!
Steve@B&B
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 8:18am
They make great stands for your bench grinder
Edited by john2189 - 26 May 2019 at 8:19am
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 8:29am
The only difference between the older C and B torque tubes is the tapped hole for the steering box bracket. I have drilled and tapped the B torque tube for a C. The newer B torque tube are the same as the CA for more holes for mounting equipment which means you can use a CA torque tube also.
