Allis C Rear Axle Lube
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Allis C Rear Axle Lube
    Posted: 06 Aug 2017 at 12:42pm
In regards to the long axle shaft that runs through the top of the axle housing from the rear end to the top of the bull gear , how do the bearings on each end of the shaft get any lubrication?
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 1:56pm
The only lube that bearing gets is from the excess from the small gear and what might be slung off the bull gear. Leon
