Allis c help |
Post Reply |
weaver
Bronze Level Joined: 10 Jul 2010 Location: central il. Points: 14 |
Posted: 10 Jul 2010 at 5:48pm |
Having problems with something drawing my battery down maybe someone could lead me the right way. Rebuilt the generator,starter, new wire harness,new battery ,new cables,new switches ,new gauges . Worked fine for a month or so now something just draws the battery down fairly quick,what should i look for? Thanks Btw its a c and a 6 volt system.
MilesGray (CO/KS)
Orange Level Joined: 13 Sep 2009 Location: CO/KS Points: 729 |
http://www.allischalmers.com/new/forum/forum_posts.asp?TID=14963&title=allis-c-electrical
Here are a couple of other posts that may help.
If it seems there is a drain even when the switch is off, you may have a hot lead coming off your generator that has constant power, or you may have gotten a bad 6V battery. Since they are not in demand sometimes they sit a long time before someone buys them. I also just finished replacing my entire Electrical/Starter system in my C. Mine is 12V but I had a wire coming off my Alternator that was live, even when the switch was off.
Good luck with the puzzle, and Welcome to the forum!
Edited by MilesGray (CO/KS) - 10 Jul 2010 at 7:04pm |
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
Chalmersbob
Orange Level Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
do you have ther cutout on the generator? they sometimes stick and will drain the battery. If it's not that, then remove a battery cable and with a volt meter in series with the battery, disconnect wires until the voltage drain goes away, as seen on the volt meter.
Bob
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2398 |
Chalmersbob has a good suggestion - the cutout can and does stick closed when you shut the engine off. Turns the genny into a motor! I'd check that first.
WC, CA, D14, WD45
weaver
Thanks guys will work on it next weekend and see what i find! Thanks for the welcome ,i have been on the old forum for a couple years but just now registered to the new . I didnt post much i just got lots of help off here. Thanks again guys!
Post Reply | |
