Allis C 12v conversion
Shane1304 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shane1304 Quote  Post ReplyReply Direct Link To This Post Topic: Allis C 12v conversion
    Posted: 02 Jul 2025 at 7:47am
forgive me I'm sure this type of question has been presented before.In order to change over my 6v system to a 12v system, do I need to change anything with the magneto? I understand the change in grounding and the alternator conversion over the generator and wiring, just not sure how it affects the magneto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 1:47pm
Changing to 12 volts on a C will have no effect on the magneto, except when spinning a 6 volt starter with 12 volt could turn the engine over fast enough to  override the impulse and not allow the engine to start with the advanced timing. Also on the smaller tractors switching to 12 volts it will hasten starter ring gear wear and could also lead to bendix problems. although many say they done this without any troubles. Do you feel lucky?
Having your starter rebuilt as a true 12 volt unit will slow the starter speed down enough to eleminate the above mentioned issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 3:08pm
magneto has a kill switch to ground it... no power to the mag..
I have several tractors that all run 12v systems / alternators.. with the original starters.. If it is setup right, with a good mag and good carb... the motor should turn over 1-2 times and start.. Will not have time to get up to "fast rpm" ....Think of an engine that is crank started by hand.. Only turns over ONCE and its running...
This page was generated in 0.057 seconds.
