allis b
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: allis b
    Posted: 13 Jun 2010 at 10:21pm
one of my Bs  leaks oil really bad both sides from  the top of the motor. I assume its the valve cover, but it looks like it could be coming from the head, can it leak oil from the head ?
 and the exhaust is very load, can the muffler be bad ?
john
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 10:56pm
valve cover is common if it is a good leak. head will seep a little at the head gasket, normally not a lot. reach up under the hood with 9/16 wrench and tighten valve cover nuts and see if that helps.. wipe it off and watch.   Old mufflers sound loud, also look for holes in the side of manifold pointing straight out the side.
This page was generated in 0.107 seconds.
