Allis B
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: Allis B
    Posted: 08 Apr 2010 at 8:47pm
I went to start my model B after sitting 6 months.  It turned over fine but no start or smoke from exhaust.  Where should I start looking?  Thanks.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 8:55pm
Engines need 3 things to run. Fuel, Spark, and Air. I'd start with the first 2 by checking your spark plugs/magneto, then check your fuel lines. If it's none of those I'd check the carb. Might be time for a good cleaning, especially if your running gas that has 10% ethanol in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 9:03pm
Thanks.  Forgot to mention it's still 6 volt but Mag was converted to Delco/Remy ignition.
