Allis B no spark
cjallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Topic: Allis B no spark
    Posted: 08 Aug 2025 at 7:45pm
Got an issue with spark. Tractor has been sitting inside for 10 years. Rebuilt head, lots of new parts. Magneto did throw spark last time I ran it several years ago. I did clean the points. They were dirty. Any help to troubleshoot the issue would be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 7:52pm
there may be a corrosion on the point that dont WIPE OFF.... you might want to use a very fine sand paper or point file to get more AGRESSIVE....
Once you guarantee the point is OK... the condenser next to it is suspect, then the COIL.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 7:54am
You said that you cleaned the points. Are you sure you got the gears timed correctly when you reassembled it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 6:12pm
It actually wasn't timed correctly but now it is. Points I cleaned with a brush.still nothing. Is there anyway to test with a meter at the coil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 6:34pm
coils for mags are hard to test.. If it is the old BLACK TAR COIL, it might be suspect...If the coil is plastic coated and red or similar, i would clean the point more agressive ( i dont know how a brush could do it... i would use sand paper or a file) .... and change the condenser.... and make sure the point is not grounded, condenser not grounded, ground strap on the outside of mag insulated.
you can clamp the mag in a bench vise and put a couple wires and spark plugs on and ground them together... turn the mag IMPULSE with a pair of pliers and look for the spark... you can feel the spring WIND UP, then SNAP.. ??
Edited by steve(ill) - 09 Aug 2025 at 6:37pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 7:25pm
Originally posted by cjallis cjallis wrote:
... Is there anyway to test with a meter at the coil?
The secondary windings (high-tension side) of the coil will read somewhere between 5,000-10,000 ohms; if they read open (infinity) the coil is bad.
The primary side is more difficult, it will be about 0.5 ohms (that's 1/2 of an ohm). This requires a pretty good ohmmeter, and is not definitive even if it looks good.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 7:47am
I had a problem with my B mag and sent it to Steve @B&B custom circuits  937632559six. It work well after he fixed it.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 8:12am
had to put a battery dist on my B --- problem solved!! Mags are junk from the word go!!
Ttague39B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 8:11pm
On my allis B I had a rebuilt man, ran great for like a year, sat for a couple months then nothing, had to free up the impulse and took a condenser out of a old $5 mag I bought to rebuild put it in and throws better spark then ever.
This page was generated in 0.186 seconds.
