Allis b mag does not contact governor gear
KKelley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KKelley Quote  Post ReplyReply Direct Link To This Post Topic: Allis b mag does not contact governor gear
    Posted: 16 Apr 2018 at 7:09pm
Help on adjusting this
Fairbanks Morse J4B3A
I miced the depth of mag gear and it does not contact slot in governor gear correctly
Thus does not rotate the mag when installed
Seems mag barely touches the governor gear.
Mag works great on test bench
Edited by KKelley - 16 Apr 2018 at 7:14pm
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 7:32pm
Most have this screw to hold it back.
Some don't!
The ones that don't sometimes have the problem of the shaft wearing thru the governor cover.
On the ones that don't I have placed a piece if brass in the bottom of the bushing inside the cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KKelley Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 8:00pm
I seen that bushing on the parts diagram and wondered if I could make a lil magic there. This is my first Allis B and have not ventured in the governor yet. Water pump leaks too so I will try to kill both if those birds next. Thanks Dick L!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 8:40pm
Here is one that didn't have the screw.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 9:07pm
