Allis B hydraulic
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Topic: Allis B hydraulic
    Posted: 27 Oct 2021 at 8:56am
Hi all I have just about finished my B restoration and had it running for the first time today and worked the hydraulics the ram went out but I can’t get it back in even with some weight on it the lever is in the down position. I don’t want to start pulling things to bits Willy nilly because of the new paint job were should I be looking first.thanks for your help in advance
Tractors Allis EB,two C,diesel G
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2021 at 12:07pm
If the packing nut is too tight, that will cause that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2021 at 3:59pm
You can use a bar clamp to push it back in... best to have an implement on the tractor and its weight and mechanical advantage should push it back in.  Paul is right, the packing it holding it.. they get old and hard.... might still be OK once some weight on it... 200 pounds might not be enough.
This page was generated in 0.153 seconds.
