Allis B engine weights? |
39allisB ![]() Bronze Level ![]() ![]() Joined: 08 Feb 2018 Location: Ohio Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Feb 2018 at 7:50pm |
anyone have an idea where to get engine weights, i am using a 39 B with 3 point, and using it weekly to do a mini farm. thanks.
rpropst ![]() Orange Level ![]() ![]() Joined: 19 Jan 2013 Location: NC Points: 279 |
I have a set in NC but that's a long ride 200.00
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
how much do think they weigh - i could pay the ship
According to an old post 90 lb each Does your front plate have the holes for weights?
no it doesn't have hole for post but i would think simple drill n bolt w spacer would work, maybe.
allisrutledge ![]() Orange Level ![]() Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1360 |
Y'all need to meet at the GOTO IN GRAY TN. Trade and see the show! Just drumming up visitors. Scott
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87651 |
this is a 175 pound old wheel weight cut in half....... had it laying around the farm several years ago........... half on each side. ![]() Edited by steve(ill) - 09 Feb 2018 at 5:54pm |
Hubnut ![]() Orange Level ![]() ![]() Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Now that's cool! |
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24658 |
OK, I have a silly question...
Would adding wheel weights to the FRONT rims be 'better' than side weights? curious as I have a set collecting dust.... Jay |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3042 |
I like the wheel weights better better because the weight is directly to the ground. The side weights add weight to the axle pivots and bearing causing increased wear. Probably doesn't make too much difference. Use whatever you have or can get.
Dave is right..... adding frame weights is like putting a loader on a tractor. Puts more weight on the spindles and bearings.. also causes more wear to the steering parts... Wheel weights are always a better plan, but access to them is much more limited. Some of my small tractors only get 50- 100 hours a year so I don't think its a big deal. If I was running 500 hours a year, I might look for wheel weights.
marion ![]() Orange Level ![]() Joined: 19 May 2010 Points: 586 |
I built a concrete mold to cast reproduction front wheel weights out of lead.
B side weights would be easy local tire shop will give me all the weights I wasn't, or you can get them from salvage yard if you painted them nobody would know the difference lead weighs 50% more than cast iron
Ranse ![]() Orange Level ![]() ![]() Joined: 11 Mar 2016 Location: Tennessee Points: 775 |
I have a similar single wheel weight with no mate to the one above. It would take a long time to cut that thing in half with a hack saw lol.
I am going to pick up side motor weights - i have wheel weights now - about 50 lbs each w bolts. / side motor 90 each, so 180+100 up front, reason is disc on 3 pt is back a ways (the after market 3 pt works Great! but arms are longer dt bolted to tow bar) and makes tractor light when lifted and moving. advantage to longer arms on 3pt is no hitting rear tire w disc on tight turn. - i have original 1 bottom plow and cultivator (they are mid mount and Smart) but take way too long vs 3pt implements for grab n go week end small farm. / i use king kutter implements and work well no issue at all. - i am about to use a new 5 foot box blade at 450 lbs and that's the going bring front wheels up point w wheel weights. 400 ok that extra 50 is loss of steering and holy
