Allis B Brake Drum
RLBPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Brake Drum
    Posted: 29 Mar 2010 at 9:11pm
I am replacing final drive seals in my 39 B project. I have one side completed and back on. That brake drum was to say the least difficult. I needed about 12,000,000 pounds of force on my long reach puller, lots of Kroil and about a day long soaking before it would move. The other final drive brake drum is making the first one look easy. Its been soaking for several days with the puller on. I have tapped on the puller, tapped on the shaft, tapped on the drum and even lightly heated the drum with the torch. Does anyone have any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 10:16pm
i have never used a puller. i stick a power wire brush down the hole and clean up the shaft so the drum will not hit any crud once it starts to move. take the setscrew all the way out and put penetrant into the hole. i take the outboard bearing cap off, block the case with the shaft sticking straight up, and drive the shaft out. i use a 5 pound hammer and a brass plate. I have had a couple that had the splines distored a few thousands doing this and had to file the end slightly to slide back into the  bevel gear  shaft... i also put one in the 20 ton press and pushed the shaft out, but its hard to hold the housing in my small press.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 10:17pm
the "shock" load does much more than a constant "press".
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 4:57am
Light heat is for warming a can of soup. It takes real heat to expand the drum faster than the shaft.
This page was generated in 0.152 seconds.
