Allis b 6v starter switch |
Post Reply |
Brinky
Bronze Level Joined: 30 Aug 2024 Location: Uk Points: 15 |
Posted: 22 hours 60 minutes ago at 10:00am |
Hi, I’m still having starter trouble. All I have is a starter and 6v battery, no other electrics. The switch on the starter operated by a lever keeps burning the contact, then the starter doesn’t turn. I know I can change the contact to a stud, but then I’m not sure on the best way to switch the starter. Has anyone else done this ?
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3838 |
That switch can be removed and the internal copper contacts cleaned up to make a more positive contact with each other, if they are not too badly worn. If it's a new replacement switch, it may have brass contacts inside which arc and burn much more readily than the original copper ones. I have had not much luck with those modern replacements.
HoughMade
Orange Level Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 705 |
I took the switch/plunger off of mine and worked on the contacts on both sides with a file until they would make full contact across the whole width. No problems since.
1951 B
Brinky
The starter came with a switch, which was arcing , so I bought a replacement which arced even more, I have taken them both off several times and filled the switch and contact. Works briefly then burns again
JoeM(GA)
Orange Level Joined: 12 Sep 2009 Location: Cumming,GA Points: 4700 |
look at your arc marks on the contact of the switch, it may only be touching on the very edges, it may need a tad of shaping. These starters have seen many years of use, the pad on the starter may be due for a change out.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 82236 |
If you decide to eliminate the present push switch and put a STUD on the starter... Then you buy a SOLENOID and mount it between the battery and the starter... BIG wire to the solenoid.. BIG wire fromt the solenoid to the starter... SMALL power wire to a BUTTON or KEY... and then a small wire from the BUTTON to the solenoid.. Small wire carries a little current the pulls in the SOLENOID and it powers the starter..
Here is a portion of a diagram that shows the battery, starter, solenoid and a key ( or button)... 12 or 6 volt, pos or neg makes no difference. |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11883 |
If you have a local rebuilder in town, take the Starter motor to him and have him change the Starter over to a stud, and while he has it, have him run through the Starter motor to make sure all components inside are in good working order. Have him inspect the Armature and put it through some tests to make sure its good. Have him also fix you up with a Starter Solenoid and your problem is solved. Those silly switches were the worst. As time progressed, the Starter motors started failing because of the king size voltage drop at that switch. Eventually, the Armature is toast. I've done a ton of em' over the years for my customer's. BTW, since you have a B, I always tell my customer's to mount the Starter Solenoid inside the toolbox out of the elements. My B has been like that for years. Starts every time.... Steve@B&B
Brinky
Thanks for the reply’s, unfortunately where I am in the UK, all the older generation that used to repair this type of thing have retired.. it also seems difficult to find a suitable 6v solenoid, will any 6v solenoid be suitable or do I need to look for a minimum rating ?
JoeM(GA)
Paul, this might be a great time to reach out to another “across the pond friend “ Mark Everett, he is quite knowledgeable on Allis and a very nice person
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22937 |
those contacts need to be perfectly clean( no pits or crates ) AND perfectly flat ( parallel to each other) this allows all the current thought them an minimizes arcing ( which is bad) on 'trick', after contacts have been refurbished is to QUICKLY engage the switch and LEAVE it 'on' until engine starts or 'time runs out'(10-20 seconds). Those contacts arc EVERY time they connect AND disconnect. On my CA, I think I turned the 'bar' upside down to get 'fresh' copper.
dont use one made for a riding lawn mower... but any 6v solenoid made for a CAR or TRUCK ( engine in the 125 cubic inch or bigger) should be fine..
i havae a couple B tractors that i have MODIFIED with a starter solenoid.. I left the original starter switch on the tractor and made a little wedge and set screw thah holds the switch CLOSED all the time. That way it can not arc.. I have a solenoid and run the BIG CABLE from it to the original terminal on the original switch.. Didnt have to install the STUD by doing this.............. but i also use a 12v battery so the AMPS are much lower than on the 6v system..... that is a possibility for YOU , switch to a 12v system and should be a lot less LOAD on your starter switch.
Edited by steve(ill) - 1 hour 25 minutes ago at 7:35am |
jaybmiller
if running 6 volts, be sure solenoid is rated for 400 amps !
Post Reply | |
