Allis b 6v starter switch
Brinky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinky Quote  Post ReplyReply Direct Link To This Post Topic: Allis b 6v starter switch
    Posted: 14 Jan 2025 at 10:00am
Hi, I’m still having starter trouble. All I have is a starter and 6v battery, no other electrics. The switch on the starter operated by a lever keeps burning the contact, then the starter doesn’t turn. I know I can change the contact to a stud, but then I’m not sure on the best way to switch the starter. Has anyone else done this ?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 12:52pm
That switch can be removed and the internal copper contacts cleaned up to make a more positive contact with each other, if they are not too badly worn.  If it's a new replacement switch, it may have brass contacts inside which arc and burn much more readily than the original copper ones.  I have had not much luck with those modern replacements.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 1:42pm
I took the switch/plunger off of mine and worked on the contacts on both sides with a file until they would make full contact across the whole width.  No problems since.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinky Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 2:00pm
The starter came with a switch, which was arcing , so I bought a replacement which arced even more, I have taken them both off several times and filled the switch and contact. Works briefly then burns again
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 2:18pm
look at your arc marks on the contact of the switch, it may only be touching on the very edges, it may need a tad of shaping. These starters have seen many years of use, the pad on the starter may be due for a change out.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 3:54pm
If you decide to eliminate the present push switch and put a STUD on the starter... Then you buy a SOLENOID and mount it between the battery and the starter... BIG wire to the solenoid.. BIG wire fromt  the solenoid to the starter... SMALL power wire to a BUTTON or KEY... and then a small wire from the BUTTON to the solenoid.. Small wire carries a little current the pulls in the SOLENOID and it powers the starter..
Here is a portion of a diagram that shows the battery, starter, solenoid and a key ( or button)... 12 or 6 volt, pos or neg makes no difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 10:15pm
If you have a local rebuilder in town, take the Starter motor to him and have him change the Starter over to a stud, and while he has it, have him run through the Starter motor to make sure all components inside are in good working order.  Have him inspect the Armature and put it through some tests to make sure its good. Have him also fix you up with a Starter Solenoid and your problem is solved. Those silly switches were the worst. As time progressed, the Starter motors started failing because of the king size voltage drop at that switch. Eventually, the Armature is toast. I've done a ton of em' over the years for my customer's. BTW, since you have a B, I always tell my customer's to mount the Starter Solenoid inside the toolbox out of the elements. My B has been like that for years. Starts every time....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinky Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 12:22am
Thanks for the reply’s, unfortunately where I am in the UK, all the older generation that used to repair this type of thing have retired.. it also seems difficult to find a suitable 6v solenoid, will any 6v solenoid be suitable or do I need to look for a minimum rating ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 5:47am
Paul, this might be a great time to reach out to another “across the pond friend “ Mark Everett, he is quite knowledgeable on Allis and a very nice person
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 6:08am
those contacts need to be perfectly clean( no pits or crates ) AND perfectly flat ( parallel to each other)
this allows all the current thought them an minimizes arcing ( which is bad)
on 'trick', after contacts have been refurbished is to QUICKLY engage the switch and LEAVE it 'on' until engine starts or 'time runs out'(10-20 seconds).
Those contacts arc EVERY time they connect AND disconnect.
On my CA, I think I turned the 'bar' upside down to get 'fresh' copper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 7:26am
dont use one made for a riding lawn mower... but any 6v solenoid made for a CAR or TRUCK ( engine in the 125 cubic inch or bigger) should be fine..
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 7:32am
i havae a couple B tractors that i have MODIFIED with a starter solenoid.. I left the original starter switch on the tractor and made a little wedge and set screw thah holds the switch CLOSED all the time. That way it can not arc.. I have a solenoid and run the BIG CABLE from it to the original terminal on the original switch.. Didnt have to install the STUD by doing this.............. but i also use a 12v battery so the AMPS are much lower than on the 6v system..... that is a possibility for YOU , switch to a 12v system and should be a lot less LOAD on your starter switch.
Edited by steve(ill) - 15 Jan 2025 at 7:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 8:03am
if running 6 volts, be sure solenoid is rated for 400 amps !
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 8:32am
Paul
An example of an Allis 6 V Starter Solenoid would be the Model D-14.
The Allis P/N is 223334, the now AGCO P/N is 70223334.
Edited by Gary - 16 Jan 2025 at 8:36am
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 9:02am
Steve any chance you could post a pic or a diagram on how you modified the switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 12:27pm
Mike, here are a couple pictures of two different starters. The whole goal is to replace the PUSH arm on the switch with a different arm that HITS the switch case at the BOTTOM and will not rotate... at the same time the other end of the arm needs to PUSH the button in for contact.. I have made a couple and if they dont PUSH hard enough on the button, you can spot weld a tit on it and then reinstall.. in one photo you can see i just slide a piece of sheet metal in the contact point to get more push on the switch.. and then put a drop of RTV on it to hold in place.....
First one i made had a nut welded on the top and a 1/4 inch screw pointed at the BUTTON.. and you just screwed it in to hold the button down... These are much simplier, once you get the dimension right.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 1:22pm
Thanks for posting. So you replaced the the switch lever with a new piece to hold the switch in engaged position then wired solenoid etc. Seams easy enough.
Edited by mdm1 - 16 Jan 2025 at 3:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 3:32pm
yes... the old switch ALWAYS ENGAGED takes the place of installing a NEW STUD....Dont seem to arc or wear as long as it is Always engaged.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 4:47pm
Over 20 years ago I had the Autolite starter for my C rebuilt by an old-time shop. He replaced the contact lug with a threaded stud. he then attached a compact little solenoid, about the size of the original mechanical switch directly to that stud. There were two little tabs that screwed the solenoid to the tapped holes that held the original switch on. then the large cable from the battery bolted to a short stud on the side of the solenoid. The small 14-16 gauge wires ran up through the tool box to a heavy push starter switch mounted on the top corner of the battery box. Made for a nice clean installation. It's still working great. My only regret is that the original switch was a real nice operational switch, that I didn't get back from the rebuilder. I didn't realize that the Autolite specific switches were as rare as hens teeth!! I have an Autolite starter for Dad's B that needs one right now! Went to the parts box & dug out a Delco starter to use instead!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 7:57pm
Good move Kip!  Don't get me wrong, Autolites were good Starters, the switches are just about extinct. I had a pile of them switches years ago, and that was before I got into the Tractor arena. I still have a pile of internal parts for Autolite units. Once in a great while I'll get an Autolite Starter in to rebuild. Switches though, are loooong gone.....
Steve@B&B
