Allis B 3 questions
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: Allis B 3 questions
    Posted: 03 Sep 2011 at 5:59pm
My son got his 52 b  running again today after we think  10 years or so,   but   the mice were in the clutch and of course it is stuck.  Any way to free it short of  splitting   ???  he has tried  running and popping.
Have a 38    B   low serial number, mostly original, runs like a top, good good rubber good paint,  hand start, hand brakes , nelson under hood muffler.   What should should it be worth???
Assuming the 52   B  clutch gets freed up, like new rears, so so fronts, electric,   foot brakes,   all there but rusty sheet metal, runs out perfect.    What should it be worth ?????
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 6:10pm
Not sure what you mean by running and popping but if you drive it in high gear with the clutch pushed in and stomp on the brakes you may pop it loose, it worked on a TO30 I had. Price of the early one can vary depending on how early it is but there is a limited market of people who are willing to hand start tractors. As far as the newer one I paid $600 for my 1950 B with a belly mower but I'll admit that was a good deal.
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 8:43pm
I unstuck an old 4500 ford backhoe clutch by removing the starter and soaking the clutch with penetrating oil , reinstalled the starter,and then  drove it around with the clutch pedal tied down and stomped on the brakes a few times. [ Be careful you got plenty of room to do this] On a B you might be able to spray enough penetrating oil up through the  the bottom  access cover on the torque tube.
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
