Allis air cleaner, what is it?
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Allis air cleaner, what is it?
    Posted: 07 Jan 2011 at 5:52pm
What does this air cleaner go to?
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 6:43pm
Looks alot like the one on my W201 power unit, but not exactly the same either. What do the mounting brackets look like?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 6:52pm
Just 2 bolt holes through a metal flange, where the hand is holding the air cleaner.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 6:52pm
Possibly WD45 Diesel.
Its alot smaller than the pictures make it look.
I didn't measure, but my guess is that the diameter is around 5".
Edited by Don(MI) - 07 Jan 2011 at 6:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 8:59pm
I don't think it is a 45 diesel.   The 45 diesel has the outlet going to the right side of the tractor, so it's outlet would be on the same side as the mounting bracket and the mounting bracket has 3 holes in it.   Also it doesn't have the rib going all the way around.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 10:37pm
It looks somewhat like the one on my styled WC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 11:17am
Any other guesses?
The owner of this part thinks it could have been for a wakuesha B?
I looked at pictures, and those tractors have the air intake pipe above. This cleaner does not, and looks like its a factory cut on the top hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 11:23am
I just checked one of my reference books and it looks the same as the one on a Case V or VA. Size and color are about right for Case also.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 11:28am
It's definitely not a Wauk B. I think Phil has the answer.
are genuine." - Mark Twain
