Allis A |
Wot ![]() Bronze Level ![]() Joined: 16 Sep 2009 Location: N Points: 160 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Dec 2018 at 10:48am |
Hi, does anyone know where to find on a A the engine serial?
And also if I can find the number for what compression ratio it will stand? Thanks! |
AC: B / WD / CA / WC unstyled / U / 7060 / 710
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
Serial # is on the left side of the block. A G is for gas and a K is for distillate fuel.
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Unless you have the piston out ,its hard to tell what compression is .But if you can bore scope it , Kero piston is a dish ,Gas is flat top .Pin to top of piston height is how you tell what compression is .
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
To find your compression ratio grab the crank handle and pull it over center 4 times.
If your bag drops halfway to the floor it is kerosene compression however If your bag hits the floor it is gasoline compression ![]() ![]() |
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2541 |
Butch: i always wondered what that was telling me!
Thanks for your answer, but do you know where exactly on the left side? Ours is repainted, I can’t find it 🤔 I found the compression ratiao’s belonging to engine serials in Norm’s book. |
The engine number is located between the hand hole covers on the left side of the block. The stamping was usually pretty shallow so multiple paint layers or heavy weathering may hide it.
Ok, thanks!
allisrutledge ![]() Orange Level ![]() Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1360 |
Ain't the original bore stamped on the oil pan or block somewhere? I think it is on mine, I need to look, but sleeves may have been changed on yours.
I found the number, thanks!
Does a Model A tractor only have a water drain plug under the radiator? Our other orange friends have 2 drain plugs (one on radiator and one at engine?) Just to be shure before its freezing.... Thanks! |
Norm Meinert ![]() Silver Level ![]() Joined: 31 Oct 2010 Location: Davis illinois Points: 470 |
The A has only 1 drain plug under the rad.
Allright, then it should be empty now. Another question: Does this engine have wet cilinder sleeves or dry? Thanks again!
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34353 |
Wet... |
