allis 720/ onan |
Nate (OH)
Joined: 12 Sep 2009 Location: Bellevue, Ohio Points: 216 |
Topic: allis 720/ onanPosted: 23 Mar 2018 at 7:37am |
All you guys that are running electric fuel pumps: what are you running? Most guys I see running them are running the facets. Specify what you use and PSI. Getting tired of having to purchase fuel pump rebuild kits every year.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Posted: 24 Mar 2018 at 8:31pm |
i use a facet,( i think it's the 3-4 psi) but i find that the heat from the engine will cause them a premature failure, i mow 3 acres with mine (so about 55 hours per year) i usually get about 3 years out of one.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
ac720nut
Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Posted: 25 Mar 2018 at 7:28am |
I also use the Facet, so far no problems
Nate (OH)
Posted: 25 Mar 2018 at 4:01pm |
We use ours for about 6 acres a week and odd jobs so hours normally get racked on lol. For the last 2-3 years we've had to rebuild the stock fuel pump because the diaphram and seals keep going out. We normally run them empty of gas and run stabil through them before putting away for winter. Works well for the most part except this ongoing issue. Does the 3-4 psi seem ideal? I was leaning more toward the lower 1.5-2 models.
Edited by Nate (OH) - 25 Mar 2018 at 4:02pm |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5488 |
Posted: 25 Mar 2018 at 8:33pm |
Still running the stock pump on both of my 720’s. Haven’t had this issue before. Rebuilt the pump as part of a restoration 7 years ago in one of them. Not sure what’s causing the issue.
talntedmrgreen
Joined: 25 Jun 2013 Location: Caledonia, MI Points: 477 |
Posted: 26 Mar 2018 at 9:27am |
You're going to want the lower PSI pump....3-4 psi will push a lot more fuel than you need. A nice mod, even with the lower pressure pump, is to enlarge the bore in the fuel return line fitting on the carb. The oem hole is very restrictive, and when converting, you can end up with fuel in your oil quickly if your pump overwhelms the carb and the return can't handle the flow.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Acdiesel
Posted: 30 Mar 2018 at 11:00am |
YES, I DID HAVE TO DRILL OUT THE RETURN, SO FAR AFTER 7 YEARS HAVEN'T HAD ANY CARB/FLOODING ISSUES.
DAN
Nate (OH)
Posted: 31 Mar 2018 at 3:04pm |
That's a sharp looking 720! ![]() The one on the left we picked up at an auction. Supposidly had been gone all thru but since we've acquired it we have done nothing but replace things lol. The one on the right was my great grandfathers who purchased it new. We acquired this one after my great aunt had sold her farm.
Edited by Nate (OH) - 04 Apr 2018 at 6:38pm |
chainweaver
Joined: 09 Feb 2014 Location: west central m Points: 62 |
Posted: 19 Apr 2018 at 3:35pm |
Nate, try using Startron stabilizer. I quit using Stabil when it ate the gas line on my jd. Had to replace from carb to tank. A friend said stabil will rot from the inside out. Just my two cents.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42275 |
Posted: 20 Apr 2018 at 6:02pm |
this one on amazon for $12 W8sunjs Universal 12V Heavy Duty Electric Fuel Pump Metal Solid Petrol 12 Volts ![]() See walmart has this online for $18. https://www.walmart.com/ip/New-12V-Low-Pressure-Universal-Electric-Fuel-Pump/197963606?wmlspartner=wlpa&selectedSellerId=4241&adid=22222222227061826623&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=165546459570&wl4=pla-272691342691&wl5=9019700&wl6=&wl7=&wl8=&wl9=pla&wl10=113537607&wl11=online&wl12=197963606&wl13=&veh=sem Been using this style on my trucks and on mower engines instead of on both Kohler and other engines - they do come in different pressure ratings On old White Dump truck it supplies enough fuel to run the 400 cu in 6 cylinder engine Edited by Coke-in-MN - 20 Apr 2018 at 6:08pm |
Toscani NE SD
Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
Posted: 21 Apr 2018 at 7:19am |
I got one from advance auto, think its mr.gasket brand, low psi, been several years now still works good, but we don't have the bad gas trouble a lot of folks have out east,actually no gas troubles. still running factory pump on 620 and that's from 74
Nate (OH)
Posted: 24 Apr 2018 at 3:34am |
Appreciate the advice guys. Still weighing my options and trying to figure out what I want to do.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 26 Apr 2018 at 9:27pm |
Todays Ethenol plays havoc with rubber parts in pumps, carbs etc. That's probably your culprit if there's Ethenol in the fuel you purchase.
Steve@B&B |
Nate (OH)
Posted: 27 Apr 2018 at 2:32am |
I'm pretty sure that it has a large part to do with it. We normally run the stabil before storing to help but here lately just seems it doesn't help much. |
