allis 706 b fork lift gas perkins fuel pump ? |
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1019 |
Topic: allis 706 b fork lift gas perkins fuel pump ?Posted: 05 Dec 2017 at 8:14pm |
I have a fork lift that the fuel pump does not keep up with the carb,when it starts to run out of gas I can use the hand primer and fill the carb and runs fine, new fuel pump same as old one, what runs pump inside the gas engine , mounted higher them the diesel it can not be on cam , does it use a rod ? can not feel it hitting anything when I hand pump it and running
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55314 |
Posted: 06 Dec 2017 at 4:50am |
Easiest fix would prolly be an electrical pump, with adjustable output...
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42275 |
Posted: 06 Dec 2017 at 7:42am |
foggy memory on the pump - had the same thing with engine pump on my TLB but installing a new pump solved the problem - can't remember how the pump was driven .
Thought it was just long arm that rode on cam lobe. |
