Allis 7050 will not move. |
Post Reply | Page <12 |
Orange Level Access Joined: 12 Sep 2009 Points: 20494 |
Proper seating of the torque limiter isn't by releasing the clutch pedal. It is done with the tractor already in motion at full throttle in 2 or 3rd gear high range and then stand hard on the wheel brakes. This is a shock load and will allow the torque limiter disc to slip and center itself.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11604 |
Huh! I wonder / hope the mechanic that had mine apart a few years back knew about this. He never said anything to me, so either he did it himself (sorta doubt it) or he didn't know. Did I get extremely lucky? Is it too late to do any good now?
If they're not centered, they don't last very long at all.
Tbone95
He must have done it then. It's been probably 4 1/2 years, 300 hours.
Ron(AB)
Orange Level Joined: 27 Dec 2009 Location: Alberta Points: 958 |
Sometimes you can be lucky by not doing the centring/slipping procedure on the torque limiter.
I've done a couple and have not done it. (I didn't know) I plow and use a deep tillage cultivator, so by putting it in deep and making the tractor pull hard, it can center. I wouldn't worry about it after 4 + years. |
45 turboa-
Orange Level Joined: 04 Feb 2012 Location: coral city wi Points: 441 |
Man I work way way to cheap and then I feel guilty sometimes !
turbocharged
Blue Yonder Farm
Bronze Level Joined: 21 Jul 2016 Location: Sheridan WY Points: 17 |
Anyone want a two week work vacation to Northern Wyoming? Work in a heated shop on a 7050 AC. Come hunting Mule Deer with us. Help butcher a pig. Work on our tractor. Send home some deer that my family harvests (sorry you can not do the harvesting but can watch us!), hog, maybe a lamb in freezer boxes. Plus rate some cold hard cash in your pocket home....
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8280 |
Wow!
Sounds like a great working vacation! Someone on here might just take you up on that! Regards, Chris |
old farmer
Silver Level Access Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
Back in the seventies I put a disc in without removing the cab. We took the AC compressor off and left all lines hooked up, we put all AC components on the steps. If you have front weights, take them off, you will not be happy if you don't.
Orange Blood
Orange Level Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
When do you need it done? |
Still in use:
Blue Yonder Farm
I will talk with the Banker Spouse
Acfarm
Bronze Level Joined: 05 Oct 2014 Location: Portland,Or Points: 143 |
Always good to consult with the bank first
Man! A heated shop........ that makes it almost too easy! Wish mine was.....would have made all my splitting experiences a LOT more plesant. I would totally be down for helping if only my Scheduler Spouse would allow it ~Warren
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8239 |
Don't know how a 7000 series compares but I had to pull the tranny out of my 8070 and supported the front of cab with lengths of 1 1/2 pipe with 1in redi-rod and some nuts and washers to make a crude screw adjustable "jack".The A/C stuff was unbolted and tied/laid in cab.When I split it later to fix the leaking rear main I don't remember having to do anything to the cab.Maybe they are made different?
I don't remember if the book gave guidance on removing the PD but it is HEAVY!!!!! and back in a hole so theres no good way to get hold it.I had access to a truck transmission jack(heavy) and made a bracket on it to pull/install the PD. |
I've pulled dozens of them out over the years.....by hand. Have a bench very close by to lay it down on. Probably 150 lbs ??
jiminnd
Orange Level Joined: 16 Sep 2009 Location: Rutland ND Points: 2235 |
I had a 7030, stopprd to adjust disc, back in tractor and would not move. Had splines gone off a shaft but don, tremember which one. Had it apart a couple times for power directer work and the shaft and never removed the cab, local dealer did it and did several that way.
