Allis 7045 - Hydraulic Shenanigans |
DanielW
Topic: Allis 7045 - Hydraulic ShenanigansPosted: 26 Oct 2025 at 11:40am |
Hi folks,
A while ago I posted about a 7045 that had (according to seller) some strange hydraulic issues His descriptions didn't add up (no power steering, diff lock stuck on, PTO working). I decided (for a while) to pass on looking at it, as I don't need another project. More recently, he dropped the price (pretty much to scrap price), and I noted the rubber was good. Rears were the same as my White, fronts were the same as my combine - both which I desperately need new rubber for. So I decided to grab it, give it a quick once-over to see if I could get it functional, and if not I'd peel the rubber off, possibly pull and sell the 426 (which runs like a top), and scrap the rest. I'll still probably do this, and I'd still come out financially ahead. But I thought I'd spend at least a little time seeing if I can fix the hydraulic issues first. Thus far I've pulled and replaced both sump filters. Both are now correct length, and I've verified the trap door is opening in the LH one and filling the sump housing. Old LH one wasn't stock and a little short, so I was hoping this might be my problem (no such luck). Pulled apart and cleaned divider/priority valve on the gear pump. The spool was stuck, but it was stuck in the up (priority/steering) position, so it really should still have had steering. Of course I left my hydraulic test box with everything I need to properly analyze pressures at my other farm, but to test flow at the gear pump I opened the test port, put a bucket under there, and fired it up for a few seconds - just to make sure I had flow and the gear pump was working. Absolutely nothing at all. No flow, and pretty much no bypassing when shut down (maybe 1 drop every 20 seconds). This makes me think something is up with the gear pump drive - stripped drive splines were my first thought (assuming it has a splined connection between the trans and gear pump - I haven't dug into the parts books to know for sure). Clutch works (PD trans) and drives fine straight forward and back, so it seems the Geroter pump is working. The flamdoozler for me, however, is that the brakes work reasonably well. Which I 'think' means the piston pump is working 9but I could be wrong?). I understand that in normal operation, the piston pump is fed by the gear pump return from the power steering, but if this flow isn't sufficient it will draw from the surge cavity in the rear-end sump. which may be what's happening? Which has me flummoxed as to how the piston pump might be working and the gear pump not. But maybe the brake valves are such that the brakes can be worked (in some capacity) with no pressure from the pump - using just the pedal cylinders instead to have at least some pressure? Again: I haven't dug into the parts books to know for sure if this is how they're set up, and I foolishly left my service manual in my other truck at the other farm, so I don't have a schematic to look at. Wondering if anyone has any thoughts about what the issue might be? Still thinking a broken/sheared shaft between the tranny Geroter pump and the gear pump is a likely culprit? In which case I'm guessing this tractor is pretty much scrap (I doubt new shafts are readily available? And if they are, a new shaft is probably more than I paid for the tractor). Next time I'm back there I'll check flow & pressures at the remotes - something I should have done before, but I only spent a little time at it and didn't have my hydraulic kit with me. Any ideas greatly appreciated.
Posted: 26 Oct 2025 at 12:39pm |
Brakes will work fine, just not power assist. Takes more effort from your leg, but as long as there is oil in the system (should be) they still work unlike some competitive tractors. Sounds like a gear pump issue to me. When I was much younger I could have the pump out and on the bench and tore apart in a couple of hours.
DanielW
Posted: 26 Oct 2025 at 3:13pm |
Thanks Doc. As usual, your diagnosis is correct. I had some time between selling loads of hay, so I pulled the intake pipe off the gear pump with the idea of seeing how well fluid was flowing through the filter housing, and looking in the pump with my inspection camera. I found this inside the intake pipe: A quarter of a pump gear. I assumed because it has a smooth/polished bore that it was from the idler gear (the parts book seems to show the shaft/drive gear as one unit), but from what I saw through the inspection camera, it looks like it might be from the drive gear? Is the drive gear is keyed onto the drive shaft? Hard for me to tell: My video wasn't great. Hard to get the camera up in there to see properly. I'll maybe upload a video when I can. If I'm right and the shaft/drive gear are pooched (I'm guessing if it is keyed on there, the keyway on the shaft is also pooched), would you just replace the shaft/drive-gear and go from there? The pump looks easy to access and tear down. I told myself if this was a hard fix that I'd just pull the rubber off and scrap the rest. But I just can't help trying to get another old Allis going again. And from the (very little) time I've spent in it, I can already tell I like the cab and control layout a thousand times more than our White. I don't want to put too much money into a tractor I got for scrap price, but if I could get this going with a reasonable amount of time/money I'd happily do it. One (stupid?) idea I had if I can't find parts (or if parts
cost as much as I paid for the tractor) was to mount a 10 GPM belt-drive pump
up front (probably where the AC compressor is, as I don't think the AC works).
Run a suction line from the filter housing outlet to the inlet of the new pump,
then from the new pump outlet to the old gear pump inlet. Not ideal, as the new
pump would be above the fluid level. But with a good check-valve to prevent
drain-back and for the minimal amount of time I'd use this per year, it may be
worth considering? I'd likely have to pull the guts out of the old gear-pump to
allow free-flow through. Edited by DanielW - 26 Oct 2025 at 3:15pm |
DanielW
Posted: 26 Oct 2025 at 3:14pm |
(picture didn't upload with last post)
Edited by DanielW - 26 Oct 2025 at 3:14pm |
DanielW
Posted: 26 Oct 2025 at 3:23pm |
I should also have added to my last post: I had to move it a little more out of the way today. Still didn't have any hydraulic test equipment, but the three point works, there's flow to the remotes, and the brakes definitely feel power-assisted, so I think the piston pump is working(ish)
Edited by DanielW - 28 Oct 2025 at 6:29am |
Posted: 26 Oct 2025 at 4:53pm |
Find a complete dual pump assembly out of a salvage yard tractor and make a good one out of two. A black tractor pump is better than a maroon, but anything is better than what you have.
DanielW
Posted: 26 Oct 2025 at 7:15pm |
Thanks again Doc. I'll call around, but not sure I'll have much luck. Only one yard within 100 miles of me, and I know for sure they don't have any large Allis's in there. There's another one about 4 hours away that might have something, but I know from experience they'll likely want at least $1-2k for a unique and hard-to-fond hydraulic pump. No other yards within several hours of me.
Do you happen to know which tractors have interchangeable pumps? From the parts books, it looks like all the 7010 through 7080, and 8010 through 8070 use some of the same internals. But I'm not sure if the pumps were entirely the same? Here's a link to the video of the pump through my inspection camera. Not a great picture, but it looks like both gears are missing sections. Later in the video I bump the engine over and you can see the shaft's keyway. |
Posted: 26 Oct 2025 at 8:11pm |
7010 thru 7080 and 8010 thru 8070 will all INTERCHANGE. From 1973 thru 1985 there were several changes to either the gear pump or the transmission pump. Regardless, a 1985 pump will fit and work on a 1973 tractor. Be careful if you disassemble what may be a good pump. The only seal or part available is the shaft seal between the gerotor pump and the gear pump. Nothing else is available anymore I think.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2425 |
Posted: 26 Oct 2025 at 10:05pm |
The 8000 series FWA tractors use a different gear pump than the two wheel drives. If you get the correct intake tube, it should work. I may have some usable gears, but it usually garfs up the housing when they break.
DanielW
Posted: 28 Oct 2025 at 8:00am |
Thanks again for everyone's replies. As I should have guessed, I'm turning this tractor into a new project and am getting more eager to try and get it going - despite what I told myself when I bought it. Opened up the gear pump yesterday. The housing looks surprisingly un-marred. I realize that it's not the kind if thing you typically check only by eye, but I'm willing to put a new set of pump gears in it and see how it does. It sounds like Lynn has a set of usable gears he's willing to sell - just waiting to get a shipping price. The keyway on the shaft is a little damaged on the driving surface, but I'll bring it into our machine shop and have the keyway widened a smidge past the damaged region and have a custom stepped key made for it.
In the meantime, I'm guessing the gear pump failed from sucking up some debris and getting it wedged between the teeth and housing (or between gears). I'd really like to drain/clean the sump as best as I can. From what I gather from the schematic, the piston pump primarily gets supply oil from the gear pump as it returns from the steering/cooler? And it appears to return from the cooler and feed the piston pump via the second (RH) belly filter, so the oil has theoretically passed through two screen/filter steps before it gets to the piston pump? But (from what I understand) if flow from the gear pump is insufficient for the piston pump's demand, it appears that it will draw from the surge chamber, through no filter (or even an inlet screen). That seems a little odd, but I guess it's better than risking running it dry. I think I read somewhere in the manual (can't find the page now) that the surge chamber is directly open to the rest of the rear-end a few inches from the bottom? I'd really like to reach in and clean inside both the main housing and surge chamber as best as I can. I think I can access most of the rear housing by removing the LH filter housing, but I'm wondering if there's a way to access the surge chamber? Also wondering if it would be a stupid idea to put a couple of those ultra-strong rare-earth magnets in the rear end before I put the filter housing back in. Just an extra precaution to try and catch any metal still floating around. Stupid idea?
Edited by DanielW - 28 Oct 2025 at 8:09am |
Posted: 28 Oct 2025 at 6:09pm |
The surge chamber gets filled by clean oil coming from the RH filter and passing thru the tube that feeds the piston pump (if it wants any oil) and if the piston pump isn't demanding oil, the oil then goes on to the surge chamber. It's like filling a bath tub. When the surge chamber is full, the clean oil spills over the wall into the rear main housing. I've never cleaned one. Never saw the need because it's clean oil that was pumped into it. Why the surge chamber?? If the piston pump is at full output, the charge oil from the RH filter cannot meet the 23 GPM flow of the piston pump. At this time, the piston pump draws oil from the surge chamber AND the RH filter to keep the piston pump happy. You can remove the left hand filter assembly and pretty easily clean the floor of the rear main housing. A couple of magnets in there on the floor sure wouldn't hurt anything.
DanielW
Posted: 28 Oct 2025 at 6:34pm |
Good to know, Thanks Doc! If Lynn is able to provide me some gears, I may be good to go. I'd sure like this to become my new baling tractor instead of my hateful White.
bigal121892
Posted: 29 Oct 2025 at 6:42pm |
DanielW
Posted: 30 Oct 2025 at 7:50am |
[/QUOTE] Just curious, what about the White you don't like?[/QUOTE]
I could go on for a while about the reasons I hate the 2-105, but I also acknowledge most of these are personal preference. The short version would be: - Vickers PVB/PVE-series hydraulic pumps used on them (or rather, the hydraulic system in general). From what I can tell (though I'm no expert) They seem even more problematic that the Allis ones. Probably due to a less than stellar filtering circuit (suction filter bypass does not have any strainer, and the geroter pump for the steering/cooling draws from the reservoir and dumps to the outlet of the piston pump through no filter). I'm lucky in that my problems were just crapulence in the compensator valve causing the spool to stick (and a couple of perished o-rings), but I know of a few 85's in the area (and read about many more online) that have been scrapped or left in fence rows when these pumps wear out and bypass. They probably wouldn't be bad for someone who's owned and maintained them well since new, but for someone like us who bought used, you're at the mercy of whatever goofballery maintenance has been done by previous owners. And I do, of course, realize the irony of complaining about the While hydraulic system, when I started this thread to talk about the pooched hydraulic system on a 7045. - The White has the worst cab and control layout I've ever experienced. All control levers rammed into the same few square inches of space, a throttle with only about 2 inches of travel, terrible cab noise and sightlines with horrible window operation, and a crude 6-speed stick that operates ungainly and clunky right in your genetalia. And I don't like how the over/under freewheels in underdrive. That wouldn't be a problem on flatter land, but with our steep and rocky hills where (try as you might) you're frequently shifting to suit varying slopes and load conditions, it's a real pain. I love the old Olivers with the Hi/Low neutral, but on the White it just feels ungainly and antiquated. And it seems like the perfect speeds for most of our field work would be in underdrive, but on our hills we really can't ever use underdrive, because every 40 yards the topography changes and you're heading down a steep hill again, and you'd be freewheeling in underdrive. In short: Something about the White just feels large, cumbersome, and ungainly. And whoever designed and laid out the White cab/controls was very sadistic.
Edited by DanielW - 30 Oct 2025 at 8:52am |
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1590 |
Posted: 21 hours 43 minutes ago at 5:56pm |
Tell us how you really feel....
