Allis 7040 Remote Cables
JoeOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeOnt Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7040 Remote Cables
    Posted: 06 Sep 2024 at 8:32am
Good morning. Getting a 7040, not sure on the S/N, I did note it before, and determined it was a 1975, but the S/N split is 3540, so then I'm not sure. It has 2 remotes, it looks like originally 1 & 2 use different cables, regardless of serial. I was reading else where that you can upgrade to the black belly cables, but there a few things that are different. What's different? If one upgrades a 7040 to black belly cables, do you use 2 of the same cables? Seems like the only option if you are actually going to order 7020 cables. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2024 at 8:54am
Anymore, the serial number means nothing. Back in their day, A-C had a "kit" to replace both "small" remote cables with all the hardware/parts to update to the later heavier cables used on 7040-60-80 tractors. Any 7010-20-45-60-80 (black chassis) already came with them, as did the later model maroon belly tractors. Until you actually look at what you've got, you are guessing. The changeover is pretty detailed. I don't know if I could do one in 4 hrs or not. NO KIT available from AGCO 40+ years later.
