Allis 7040 air conditioning system
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7040 air conditioning system
    Posted: 10 Aug 2023 at 8:05am
How many pounds of r134 does it call for? Thanks! Dana
Blue Skies and Tail Winds
                          Dana
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 10:52am
on from new A6 3.8  Seltec Kit  3.25-3.4 New delco A6 3.25-3.50
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2023 at 8:55am
Thank you!
                          Dana
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2023 at 9:24am
FROM OUR EXPERIENCE.. on older systems they are like mother in laws.. each a little different.  We always charge the older systems on a 90 degree day to no more than 225-250 on the high side and it should be less than 20 on the low side WITH THE SIDE SHEETS ON. Then it will be cold at the evaporator, the air flow will determine BTU cooling - Then at about 1500 RPM close the doors and turn the fan to low - watch the low pressure - it should go to 12-14 PSI and the thermostat should kick off the compressor.  Anything abnormal, there is an issue .
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2023 at 10:35am
Thank you Tim!
                          Dana
CptPerez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CptPerez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2026 at 8:13am
most 7000‑series systems that were converted from R12 to R134a seem to run fine with roughly 70 to 80 percent of the original R12 charge. If you know the original spec, that usually gets you close. Curious if you’re still running the stock compressor and hoses, or if anything was changed during the conversion.
Vaterlemon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vaterlemon Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2026 at 8:27am
I had a similar headache last summer and ended up booking air conditioning installation basildon, which made a huge difference. The FGAS-certified team handled everything quickly, and I liked that they were around for any follow-up or emergency visits. If you want something that covers both installation and future maintenance without fuss, that option worked smoothly for me.
Edited by Vaterlemon - 16 Feb 2026 at 1:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 5:09am
That was a couple years ago I put a new compressor, new hoses, new dryer, new condenser new parts up in theroof andit cools like crazy!
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 5:12am
That was a couple years ago I put in many new parts like compressor hoses dryer condenser and up in the roof. Yeah cools like crazy.
                          Dana
