Allis 7000
Empirestate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7000
    Posted: 17 hours 28 minutes ago at 5:56pm
hello all,
  New member here. Been a lurker for a while and have gleaned a lot of useful information. Now I have a problem I could use some help. 1978 Allis,7000. It does not have differential lock, but all of a sudden it acts like it does. Just driving tractor only it steers, but with a round bale on the 3 pt. You can't turn it, not even using the breaks. I suspect something is wrong in the final drive, but what? Thanks for any help
    Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 6 minutes ago at 6:18pm
The differential is locked up. There is a dipstick directly behind the cab under the SMV sign. I'm guessing your PTO seals have been leaking oil and that compartment is very low on oil.  Wheels have to come off. Axles get pressed out of their tubes. Brakes/brake housings come off. Lift arm housing comes off next. Then, you are down to the differential with the ring gear. Cab might have to be lifted a little, but not removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 28 minutes ago at 4:56am
thanks Dr.,
  Are we talking major damage or parts not sliding as they should? I did pull the dipstick, it was low but
Still showed oil on the stick. Thanks again, Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 19 minutes ago at 5:05am
dr. Allis,
  I should have asked am I going to do more damage if I were to keep using it? I still have to feed cows
Until the weather improves, also don' t have heated shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 56 minutes ago at 6:28am
More damage?? Maybe and maybe not really. The affected parts are already junk. If you must continue to use it, overfill it 2 or 3 gallons from the top mark on the stick. Maybe even overfill with diesel fuel to act like penetrating oil inside the differential. It will not hurt doing this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 52 minutes ago at 6:32am
thanks dr.
  Won't use more than I have to . What am I looking at for ruined parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 46 minutes ago at 7:38am
Four seized pinion gears inside the differential case and a ruined cross at a minimum.  I only remember having to repair one over the years and it had 6K+ hrs on it and had done a fair amount of plowing in its iifetime.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 41 minutes ago at 7:43am
Welcome to the forum. Goodluck.
Where abouts are you located
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 3 minutes ago at 8:21am
This is the differential carrier from  an 8030 a few years back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 1 minutes ago at 8:23am
That's pretty cool, Lynn. For sure when he placed it in "park" on a hill it rolled another couple of feet !!!
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 58 minutes ago at 8:26am
Yikes! Shocked
This page was generated in 0.285 seconds.
