Allis 7000
Empirestate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7000
    Posted: 3 hours 14 minutes ago at 5:56pm
hello all,
  New member here. Been a lurker for a while and have gleaned a lot of useful information. Now I have a problem I could use some help. 1978 Allis,7000. It does not have differential lock, but all of a sudden it acts like it does. Just driving tractor only it steers, but with a round bale on the 3 pt. You can't turn it, not even using the breaks. I suspect something is wrong in the final drive, but what? Thanks for any help
    Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 52 minutes ago at 6:18pm
The differential is locked up. There is a dipstick directly behind the cab under the SMV sign. I'm guessing your PTO seals have been leaking oil and that compartment is very low on oil.  Wheels have to come off. Axles get pressed out of their tubes. Brakes/brake housings come off. Lift arm housing comes off next. Then, you are down to the differential with the ring gear. Cab might have to be lifted a little, but not removed.
