Allis 7000 Hydraulic Issue |
NNYFarmer
Topic: Allis 7000 Hydraulic IssuePosted: 23 Oct 2024 at 12:47pm |
I changed the hydraulic fluid in my allis 7000. Because there was water in the system, I blew out the lines (If I wasn't supposed to do this let me know) including the cooler, but not the pump. New filter New fluid Now when I try to steer, the wheel goes immediately to the left/right (depending on what direction I try to steer) and the steering just pounds away trying to go in that direction. The only way to stop it is to shut off the tractor and restart it. I've bled all the lines. Before this I could move the front wheels by the steering wheel without the tractor on. Now they don't move no matter what I do. The hydraulics worked perfectly before the change. Any ideas?
Edited by NNYFarmer - 23 Oct 2024 at 12:48pm |
Posted: 23 Oct 2024 at 1:51pm |
Crossed up lines somewhere.
NNYFarmer
Posted: 23 Oct 2024 at 2:49pm |
No. The lines haven't been changed at all. I'm the only one using the tractor so no one else could have done it
Posted: 23 Oct 2024 at 2:57pm |
OK. Well, you said you blew out the lines. I would have assumed that meant you had to disconnect them somewhere. So, if the lines are routed correctly, the problem must be in the steering orbitrol itself. Why ??? I have no idea. If it was steering properly before, I cannot imagine why there would be a problem now. Hydraulic filter installed backwards ??????
Edited by DrAllis - 23 Oct 2024 at 2:58pm |
