Allis 7000 Differential |
Post Reply |
KevinON
Orange Level Joined: 07 Dec 2009 Location: Schomberg, ON Points: 789 |
Posted: 20 Nov 2024 at 8:49am |
Was just wondering if there was a difference between the maroon belly 7000 differential and the black belly differential. Looking to get one to stuff in a 185 rear. Thanks!!
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3296 |
200,7000 early and late all had an assy 70253512.... but a lot of difference from a 185..
Orange Level Access Joined: 12 Sep 2009 Points: 20522 |
The RH bearing and cup are larger. Don't know if the RH bearing carrier could stand that much material being removed. We've always run the stock 2-pinion with needles on the pin and in later years went to flat needle bearings behind the side gears for thrust. We run 6700 lbs in a gear 20% faster than road gear with 24.5 x 32's , twin turbos at 1200+ HP. I wouldn't think about a 4-pinion for what we have and you'll still have to needle the 4-pinion.
KevinON
This tractor will be a 362cu in alky. We run 7000lbs here. I have no idea on what HP I will be running, but I would think it would be around 1000, give or take. I appreciate the advice. Might be just as far ahead needling the two pinion that is in it. I had heard of people stuffing a four pinion in them, that's all.
Whichever way you go, be sure to mark your transmission dipstick to carry the oil level at least 1 inch higher than it is marked for. And use 821XL or equivalent oil.
Edited by DrAllis - 1 hour 36 minutes ago at 1:55pm |
Post Reply | |
