Allis 653 Dozer. |
AndyT
Topic: Allis 653 Dozer.Posted: 01 Oct 2017 at 8:45am |
Will a 433 from a F2 Gleaner fit in a 653 Dozer?
Craig/insoh
Joined: 26 Mar 2010 Location: Waverly,ohio Points: 229 |
Posted: 01 Oct 2017 at 11:30am |
Yes same engine but the driveline will not hold up for that many horsepower! I would advise taking turbo off and setting pump and injectors to 650 series specs! Driveline parts are starting to be hard to find!
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 01 Oct 2017 at 12:23pm |
AC 2200 engine used in that series of machine was what i thought was used - was talking with a mechanic who did some work on that and said same engine was used in cotton pickers but with turbo and could be boosted to 85 HP or so .
Question is the rest of machine from clutch-pack to single reduction finals are not made for that power . If you want a 70 HP or higher machine look for something made for the job After having a HD4 and doing work on both rear cases , replacing gears, replacing axles, having cases machined after outboard axle bearings failed and ate into case webbing - the machines are industrial machines - NOT construction or excavation grade machines - the HD4 went down the road running as I got tired or repairing it , kept my HD5G , in fact the HD5B lasted a couple more years until replaced with a FIAT/ALLIS FD5 - 70+ HP machine with 6 way blade |
