Allis 645 payloader
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: Allis 645 payloader
    Posted: 18 Jan 2023 at 6:12am
Does anyone know where I can get some new flex plates for this machine? I am referring to the ones that go between the flywheel on the engine, and the torque converter on the transmission. There are four of them, three are the same, and the only difference on the fourth one, is that it has weldments on the one side of it with threaded holes for the flywheel bolts to go into. I tried minnpar, and they no longer available through them. Thanks
Darrel
Edited by darrel in ND - 18 Jan 2023 at 6:13am
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2023 at 6:33am
Check with General Gear. Website is Tractorparts.com.
Edited by truckerfarmer - 18 Jan 2023 at 6:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2023 at 8:40am
I’m curious. What’s the part numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2023 at 9:32am
Part numbers out of the allis parts book are:
Three of 3041454-4
One of 3042762-9
Minnpar part numbers are:
AC72041454
FAC 73042762
I guess that numbers are about the same.
Thanks
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2023 at 6:58am
Bump
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 9:58am
Some parts might be available through a marine supply - It's where I found parts to rebuild the fwd/rev box on my AC 715 TLB - outfit had new torque converter also in stock for machine .
