Allis 620 720 front PTO with Briggs swap |
structures
Joined: 28 Feb 2011 Location: Beggs, OK Points: 336 |
Topic: Allis 620 720 front PTO with Briggs swapPosted: 15 Dec 2015 at 9:57am |
My 620 has a generator type onan in it without the front PTO. I've been kicking around doing the briggs swap. Can you all tell me if there is an aftermarket front PTO I could bolt up to the briggs if I go that route?
Robert
1964 D15 Series II |
structures
Posted: 16 Dec 2015 at 8:36am |
Or would anybody be so kind to measure their clutch?
Need: Height of the clutch assembly DIA of pulley Belt width Thanks
Edited by structures - 16 Dec 2015 at 8:36am |
Robert
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4072 |
Posted: 18 Dec 2015 at 7:21pm |
clutch part oregon# 33-188 or warner # 5218-110 1 1/8 shaft pulley 6 1/4 for 5/8 belt makes up for a perfect match to the onan pulley stub shaft B&S #842655 muffler B&S #808911 this is what we used on a 720 two years ago
HudCo
Posted: 18 Dec 2015 at 7:25pm |
stub shaft will be used on flywheel side with oem clutch pulley drilled out and brouched
