Allis 614 forklift |
hmontena
Joined: 28 Jan 2022 Location: Pioneer Valley Points: 11 |
Topic: Allis 614 forkliftPosted: 30 Jan 2022 at 7:13am |
Just found an Allis614 forklift. It is in good shape, the motor is stuck, G160. I don't think I am going to rebuild it. I did find a 3.152 Perkins diesel Will it bolt up to trans or do I have to make an adapter plate ? Thanks
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 30 Jan 2022 at 8:22am |
I would see if you can get the engine unstuck and see how it runs. Some engines unstick easy, some are tough. Depends on where they were sitting. Outside or inside, and whether it had spark plugs screwed in it or not. Ya never know. Sometimes they break loose with different formulas poured down the spark plug holes to get things loose again... Steve@B&B
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7634 |
Posted: 30 Jan 2022 at 10:05am |
Perkins will not bolt up. You will need an adaptor plate to start with, and probably more fab work along the way. Get the G160 freed up and you can rebuild it.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5274 |
Posted: 30 Jan 2022 at 11:27am |
If you find a G138 or G149 they would bolt right in and everything would fit in place, just be a little les power.
