Allis 6080 Engine Oil level running or cold
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: Allis 6080 Engine Oil level running or cold
    Posted: 04 Jul 2024 at 11:23am
Hello, I have a 6080 y'all helped me finish the rebuild on. I have a silly question.
Do you check engine oil on running side or stopped side?
Stopped says full. Running says middle range. Just making sure I'm not missing anything.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 2:09pm
Is the tractor running or stopped? I always check oil at the start of the day, with engine off, and the oil is cold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 2:54pm
Reads full cold. Low running. That is why I'm asking this question. I was a little confused.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 8:04pm
The dipsticks on those engines were made so you COULD check the oil when at operating temperature on the level while IDLING.  More of a gen set or irrigation pump application. You have no reason to do it that way !!!  Check it cold, sitting still and not running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 5:45am
Dr. Allis, thank you,sir! I appreciate it!
