Allis 600 Series Forklift
OldSchoolRecovery View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Topic: Allis 600 Series Forklift
    Posted: 10 Sep 2020 at 9:49pm
Picked up a much needed forklift.  Tag says, Series 600.  A couple questions for the experts.
1. Where is the serial number on a 600 forklift?
2. Were the engines red, or is this a farm tractor repower/
3. The motor stamp reads 15-4744-T.  What does that make it.  I know the 15 makes it a D15, but what about the T?
Thanks for the help.  Hasen't run in a few years.  I ran it enough to get to the shop, but there is so much rust in the tank that I had to blow out the fuel line every 20 feet or so.  It need a few thing to make it good.  Starters is going to be a new fuel tank and a carb rebuild.
Oh, and then some manuals so I can learn what some of the features are.  LOL,
Thanks,
Old
1942 Farmall H
1940 Allis B
1944 Allis B
1945 2N
1947 8N
1948 8N
1951 8N
1949 JD M
1951 JD A
1951 JD AW
1951 WD
1952 Allis D Grader
1957 D14
1958 D17
1961 Case 440L
1963 IH Lo Cub<
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 5:51pm
With some paint stripper, I found the machine number. 600 1547FL.  600 is the series and 1547 puts it as a first year, 1966.  And FL is forklift, I would imagine.
I think the engine is from a farm tractor also, as I see most of the other 600's on the net have yellow engines.
Thanks,
Old
1942 Farmall H
1940 Allis B
1944 Allis B
1945 2N
1947 8N
1948 8N
1951 8N
1949 JD M
1951 JD A
1951 JD AW
1951 WD
1952 Allis D Grader
1957 D14
1958 D17
1961 Case 440L
1963 IH Lo Cub<
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 7:53pm
When I worked in the salvage yard everything got painted the manufacturers main color. Got bitched at because I painted an 8N block red instead of Ford blue. If it was Allis it was orange. Didn't matter if it was industrial
walnut1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walnut1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 9:29pm
I have an I600 forklift, the older style with rounded sheet metal instead of the flat, angular like yours. My dad bought it new in the 60’s, it’s all original yellow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 9:07am
From what I find on the innerweb, the motor is a 1961 D15.
Old
1942 Farmall H
1940 Allis B
1944 Allis B
1945 2N
1947 8N
1948 8N
1951 8N
1949 JD M
1951 JD A
1951 JD AW
1951 WD
1952 Allis D Grader
1957 D14
1958 D17
1961 Case 440L
1963 IH Lo Cub<
This page was generated in 1.092 seconds.
