Allis 5050 jumpy to no hydraulics |
Post Reply |
Allismass
Bronze Level Joined: 03 Apr 2020 Location: Massachusetts Points: 12 |
Posted: 13 Apr 2024 at 4:13am |
I purchased a low hour 5050 a few years back and the hydraulics are giving problems.
When hooked to an implement the tractor won’t lift (say a Tedder) smoothly.. it jerks and may not all all. Is it a bad hydraulic pump? I changed hydraulic oil, cleaned the filter, and even filled the pump from the top side to eliminate a possible airbound/cavitation like situation.. still does it. I also checked under the seat to see if the valve(?) was free. I found this on line on a Universal tractor. I also lost the power steering after I noticed the fluid level was low.. I filled it but the steering never came back. Is there a way to purge air out of these systems? Any help is greatly appreciated. Pete
Ac 720,160,5050,5050,175,185,6080, 200
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2928 |
Did you put a new O ring in when you cleaned the screen?Sounds like its sucking air.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3275 |
Remove the screen and run it for a few minutes. You have cavitation - 99% screen issues.. Assume you have separate reservoir - if it is full - loosen one power steering line at the cylinder- crank and turn steering wheel.
Post Reply | |
