Allis 5015 engine replacement |
cj93z
Joined: 20 Apr 2015 Location: United States Points: 5 |
Topic: Allis 5015 engine replacementPosted: 04 Jan 2016 at 5:11pm |
I bought a well used 5015 4x4 at auction early in 2015. It was smoking a bit but ran good. Unfortunately it suddenly started knocking and before I could shut it down it blew the left side of the engine with the oil pump/filter right off. Looks like the #2 piston/rod had a problem :( I've been looking for a replacement engine. I can't afford too much because like I said the tractor isn't in the best shape but everything seemed to be working ok before it blew. I'm will to travel a few hours from NJ. Will an engine from another tractor fit without too much trouble? I don't mind some fabrication. I've seen a couple 5020s for sale but I'm not sure how hard that swap would be. I really like this 4x4 tractor and it was going to replace a couple of my smaller simplicity garden tractors.
Thanks in advance for any help or advice!
Dnoym N. S. Can.
Posted: 04 Jan 2016 at 6:39pm |
will this be of any help too see
what they used them in Toyosha 1.0L 3-cyl diesel http://tractors.wikia.com/wiki/Hinomoto http://www.tractordata.com/farm-tractors /005/0/5/5055-bombardier-mpv-20.html http://www.tractordata.com/farm-tractors /000/1/9/191-allis-chalmers-5015.html B:-) Dnoym |
JacksAC
Posted: 04 Jan 2016 at 7:56pm |
If you will be selling the simplicities can you let
me know . Thanks, and sorry to hear you bought a lemon Auction equipment is at best a roll of the dice. Regards: Jack Beale 831- 710-5768 |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 05 Jan 2016 at 9:57am |
cj93C where you located in NJ?
JacksAC
Posted: 05 Jan 2016 at 10:04am |
We are located in Happy Jack Arizona
May have to pack a lunch or two. Probably need sleeping bags as well Never been your way, may be some day |
Steve in NJ
Posted: 05 Jan 2016 at 10:47pm |
Your post read like you were from NJ. I'll git' out to AZ one of these days to see my buddy Armand...
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55301 |
Posted: 10 Jan 2016 at 5:06am |
I think the same engine can be found in a MF 1010... Or maybe the 1020...
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 10 Jan 2016 at 9:32am |
Steve I think the wrong guy replied to your post. Gary |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 10 Jan 2016 at 12:15pm |
It would seem to me that once a company gets acquired by Hitachi
the end is near. |
cj93z
Posted: 21 Jan 2016 at 12:18pm |
I'm in Blairstown - not too far from you at all.
AJ
Posted: 21 Jan 2016 at 12:34pm |
Stick you a 125 in it. Easy to find, cheap to fix and find parts for and they everywhere. Just have a machine shop make you an adapter plate and might need to do something different with the clutch. Rick Corder can prolly help you figure that part out. Be alot easier to get started in them cold Winters too. Just a thought.
Can't fix stupid
cj93z
Posted: 21 Jan 2016 at 12:44pm |
I have a good buddy with a machine shop so that's not a problem. I heard that the motor is part of the frame on these machines so I don't know about that part. What exactly is a 125? ;)
AJ
Posted: 21 Jan 2016 at 12:48pm |
Just need to use your imagination and your buddy's machine/fabrication skills. It will fit I'm sure. Just gotta take that leap of faith in yourself. Good planning and research helps alot. A 125 is an engine found in most B,C,CAs.
Can't fix stupid
Steve in NJ
Posted: 21 Jan 2016 at 5:20pm |
Yer right Gary. I didn't realize it was the other guy that posted back. Wow! cj93z you're 20 minutes away via Rt94! Good to know.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 21 Jan 2016 at 6:29pm |
That whole tractor would need to be butchered to try to make it run with a 125 4 cylinder engine. Making it LOOK like a tractor after that is another adventure!
BrianC
Posted: 21 Jan 2016 at 6:43pm |
Go ahead, butcher it. I saw a 5015 re-workd to look like a D21, that was neat.
Is there a photo of that somewhere on this site. |
cj93z
Posted: 23 Jan 2016 at 12:22pm |
I don't really mind butchering it because the overall condition is a little rough anyway. Just need to do it for around $1000 or less, that's the tricky part. If I'm going to spend more than that I might as well sell it for parts and find another one in better shape.
DiyDave
Posted: 23 Jan 2016 at 5:36pm |
If you are set in re-doing it, if you start with say a kubota motor, you might find one that'll bolt right up, I don't know. My bet is that they prolly had a standard bolt pattern for several tractors, like the massey and hinmoto...
