Allis 5015 countershaft 3rd Gear
thesmallenginekid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thesmallenginekid Quote  Post ReplyReply Direct Link To This Post Topic: Allis 5015 countershaft 3rd Gear
    Posted: 21 May 2021 at 12:16pm
Hi
I have an Allis 5015. The guy I got it from must have ground into 3rd gear a little too much. When I opened the shifter cover there were no teeth on the gear.
I am pretty sure the part number is 2101079.- please correct me if i'm wrong. The gear has 32 large teeth and 30 small teeth.
I have called almost every AGCO dealer in a 300mile radius from where I live. I also called Wengers(PA), Wellington Tractor(TX), Coldwater Tracotr(Wa), and more. None of them have it.
If you know of any place the carry a large amount of NOS Allis 5015 parts, or a place that has parted out some 5015's please let me know.
Or if you have the part I would like to buy it.
Thanks
Edited by thesmallenginekid - 21 May 2021 at 12:16pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 4:12pm
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwjUjbzh19vwAhU4BogJHSdlAZoYABAFGgJxbg&ae=2&ohost=www.google.com&cid=CAASEuRokN3f7LiOE-QLKg9Oyj567Q&sig=AOD64_2Rt4N_eWPGOhvOph0DJ2--ua_8wA&ctype=5&q=&ved=2ahUKEwixubLh19vwAhUFX60KHYzXCIQQ9aACegQIARBC&adurl=
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 4:13pm
Pinion Shaft 3rd Gear
In Stock
At our Michigan warehouse
ACS285
$159.99
Post Options Post Options   Thanks (0) Thanks(0)   Quote thesmallenginekid Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 6:41pm
Thanks But that's not the right one. The gear has straight teeth big and small.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 11:14am
Check With Southern global  601-928-7491
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 7:05pm
The Allis Chalmers 5015 is the same as the Simplicity 9518.
The same tractor was sold as the MF 1010 and Hinomoto CS100 I believe.
       HTH           B:-)          Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 6:59pm
Guy on Ebay is parting one out
Post Options Post Options   Thanks (0) Thanks(0)   Quote thesmallenginekid Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 8:07pm
What is the sellers name? Do they have the 3rd gear I need?
Jasonw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonw Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 2:42pm
My 5015 has the same problem and but I have yet to tear it apart to fix it.
Here is the link for the parts one on ebay...
Post Options Post Options   Thanks (0) Thanks(0)   Quote thesmallenginekid Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 9:35am
Thanks. I cant drive to Maine to pick up all the parts. But im going to try and convince the seller to send me just the 3rd gear.
This page was generated in 0.099 seconds.
