Allis 416 |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1351 |
Topic: Allis 416Posted: 19 Feb 2024 at 11:35pm |
Good evening!!
So I’m wondering if John Deere low velocity hydraulic oil would work in the hydro? I just got it running for the first time in who knows (the battery was dated 2000) and it had a hole in the block from the balancer gear breaking. I took the block into my local blacksmith and he patched the hole and I put a new piston and rings and now it runs great!!! I have a tiller, mower deck, front blade, snowblower, and a little Allis cart for it so it’s going to be worked pretty good…. |
Mikez
Posted: 20 Feb 2024 at 12:32am |
Nice resurrection.
What did they do to fix the block. We have some nos parts for that mower deck and tractor if you need anything
55allis
Posted: 20 Feb 2024 at 9:41am |
Can you look up Allis part numbers?
I have a original parts catalog for them but the nearest agco dealer can’t look any numbers up… |
Mikez
Posted: 20 Feb 2024 at 12:36pm |
Yes my grandfather was a dealer then.
55allis
Posted: 29 Feb 2024 at 10:47pm |
So as I’m using the tractor it seems to be a weak hydro going backwards, forward is fine but if I back up over a bump it will stop…
I’ve adjusted the turnbuckle so neutral is correct (I think) so I’m wondering if anyone else has had that problem? Mikez, I’m working on a list of things to price and I will private message you when I complete it… |
55allis
Posted: 23 Mar 2024 at 10:24pm |
Well I may have fixed the reverse problem…
I extended the arm on the hydro lever so it will have more movement… Pictures aren’t very good but you can kinda see what I did..
55allis
Posted: 01 May 2024 at 9:47am |
Well it’s about to become a 416h3…
Yes I’m adding hydraulics to it with 3 ports… So far I have a 5.9 gpm pump ,part of a tank (somewhere around (2-2.5gall) still needs hose ports. Will get pictures soon but I have the hydro pump apart to put new O-rings in the control lever shaft. |
