Allis 400 loader
capn lonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote capn lonnie Quote  Post ReplyReply Direct Link To This Post Topic: Allis 400 loader
    Posted: 21 Jun 2023 at 1:49pm
So when I put hydraulic fluid in my loader, it ends up transferring into the main housing and leaking through the overflow, and my loader stops functioning… there is a loader pump that mounts below the rear PTO shaft..is there a seal that could be bad, causing the fluid transfer? If so how difficult to repair?  Thanks!
'44 B '46 C '58 D-14 '78 5050
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 3:55pm
Which tractor?  The 400 series loader usually had its own hydraulic reservoir in the left side upright support that was completely separate from the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote capn lonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 4:25pm
Tractor is a 5050, and yes, the reservoir is in the support… the pump is mounted to the rear just under the PTO shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 4:59pm
Shaft seal on the pump. Pump shaft bearing/bushing may be bad. Might have to replace the whole pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote capn lonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 6:48pm
Thanks, the pump seemed to be functioning properly with fluid, hopefully just the seal needs to be replaced
