Allis 4 bar pto rake
JaredC(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Allis 4 bar pto rake
    Posted: 22 Apr 2019 at 10:36am
So found an allis 4 bar pto rake. 10 ft long and has 2 wheels. What model would this be? Did they work ok?
May go check it out soon. Anything that I should look at in particular? They are asking $400. How's that sound for a price?
Thanks
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 1:42pm
There are a couple different models and different versions of each. The earliest ones were called Allis Chalmers PTO Rake/Tedder.  These have the front castor wheel ahead of the basket and the gearbox has a High/Low/Tedding feature. There is a serial number break for which parts they use.  Then the update version is a #7 PTO Rake/Tedder. This one has the front castor wheel behind the basket and the gearbox has two input shafts, to change from raking to tedding you put the PTO shaft on the other gearbox shaft. This rake also had a serial number break for parts.
    Both rakes will do a very good job on properly prepared ground, they do not like rough ground.  There was a optional kit for both rakes that had extra wheels on both ends and this helped quite a bit.
    The biggest problem with them is, people with rough ground over-tighten the slip clutch instead of learning how to properly prepare a seedbed, which will break the gearbox.
   I have one of the early model PTO Rake/Tedders that I will sell. It doesn't look like much with no paint, however it is in great mechanical condition with all good teeth and the extra wheels front and rear.
The best thing about these is; one single implement will do the work of two modern pieces of equipment. Properly setting the angle of the teeth for the task desired, is probably the most important setting after not setting the teeth too low.
   I also have lots of NOS and used parts for these rakes that would be first offered to the buyer of my rake.
Edited by PaulB - 22 Apr 2019 at 1:48pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 6:17pm
Jared, I wore out one of those growing up. They work well on relitavily flat ground. They usually being less than $150.00 here. They do need the ball and socket hitch to use them. I think I still have some rake teeth hanging on a wall in the shop.
Edited by HD6GTOM - 22 Apr 2019 at 6:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 8:09am
Ball and socket like on a trailer that would be pulled by a pickup or car?
I believe the rake is the early version like in the pic above.
Jared
This page was generated in 0.087 seconds.
