Allis 2000 Semi Mount Plow/ Parts
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Topic: Allis 2000 Semi Mount Plow/ Parts
    Posted: 30 Apr 2010 at 8:17am
Howdy,
Tried to sell this plow for at least scrap price,but no takers. So before I scrap it I thought I would see if anyone interested in parts. Better some orange get saved. Ita a 5 bottom, 18 inch, hydraulic reset. 715-693-6783 Thanks Kurzy
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:32am
I'd be interested in the whole plow if you were just closer. I actually am looking for a 6 or 7 bottom Allis plow for my 7050.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:37am
Joe - can you find a part number on the moldboards?  Do you know what bottom number those are?  Might be interested in the moldboards if they would fit one of my plows.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:41am
Howdy Lonn,
Not that far dont be shy. Piece at a time works too LOL
Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:42am
Howdy Mike,
Will try to find numbers for you.
Thanks Kurzy
Armand(AZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:42am
What is the model of the disk in the background?   Planning on building a couple disk models in the future but I don't have a manual on that type.   tks,   Armand
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:45am
Its an Allis 2600, primary tillage.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:52am
Kurzy, Can that plow be reduced down to a 3 bottom? Looks like you could unbolt re-sections and move wheel up is that possible?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 9:02am
I am in need of some brackets that hold the coulter onto the flat beam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 9:11am
Nice Talking with you on the plow, keep me posted, Thanks,Chris/CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 9:23am
Howdy ,
What backets you got, round or flat?
Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 10:40am
Actually now looking at the picture a little closer the bracket is different. I would need everything I circled in the picture.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 11:04am
If those shins have three bolts they could be #392 bottoms like on my 4x18 2000 monobeam. It appears there are two bolted beam sections at the rear, each holding one bottom. So they could be removed to make it 3x18. You'd probably want to remount the gauge wheel, but it likely clamps to the beam anyway. I'm sure I have a plow manual somewhere but which box its been moved in may take a while to find. On my 4x18 there were no bolted sections of main beam, but to make it 3x18, I took off the front bottom and was able to move the front hitch over 18" between where the front panel bolted to the plow and where the drawbar was clamped.
Coulters were available separately from the plow and the beam the coulters on a 2000 mount to are in the same place the plow frame of a 9000 or 60 through 70 series plow would be, so the same coulters from all of that vintage will fit the 2000. Right now the coulters are off my 2000 being used for planter straw cutting and fertilizer openers. They have suffered from being near 32%. I have replaced most of the shins and my plow did well the last time I used it, but I went no till and since have rented out the land. My plow could be bought, it will need use to make it scour. Its spring trip, but from previous deep plowing I had nothing to test the spring trips and its not sure they aren't rusted tight.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 12:03pm
Howdy Mike,
Got some numbers for you. Wiese MoldBoards, #347966 T Steel tag on 5th bottom says 581822 front four look all the same with tag on 4th bottom 568788. Hope this helps.
Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 12:41pm
Per my trusty plow bottom book (same one as Gerald), 347966 moldboard number is for a 387 bottom.   What I don't know if the same moldboards are on any other bottom like a 39x?  I need to check my plows this weekend for the same moldboard numbers.  I know my 3 bottom 73 has 376 bottoms.  My two 74's is what I need to check.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
DOlson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 9:12pm
How much do you want for the plow ? Ive been looking for a five bottom Please call me at 715-469-3480 Thank You .
orange paint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange paint Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 11:39pm
The plow is putting rusty, what do you guys do to polish up the mowboards?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 4:01am
The surface of a plow is HARD, you can polish it with a 7" grinder and a flexible disk, or just plow with it stopping frequently to scrape the dirt stuck to the rust and it will scour on its own. That's fastest in sandy ground.
Gerald J.
usshek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote usshek Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 7:52pm
Greetings, do you still have your 5-bottom plow?
