Allis 200 front wheel hub
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Allis 200 front wheel hub
    Posted: 13 May 2019 at 7:22pm
Hi y'all Dana here. I am in need of a spacer for the front wheel rim so my front tire doesn't rub on the steering arm and steering arm stop. Maybe a half inch spacer would work. Anyone sell these spacers for an XT or 200 front hub? I have big front tires and one clears ok and the other rubs slightly. I ground a little steering arm metal away but I need more clearance. As always thanks for yalls help!!! Dana
Blue Skies and Tail Winds
                          Dana
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2019 at 8:58pm
If the other side clears I vote for a bent spindle. Yes I have seen some aftermarket spindles bend.
Albert
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2019 at 9:45pm
Shoup has reinforcing rings for rims maybe you could run one on the inside as a spacer. Are the rims original and the same for that tractor and are the tires the same brand? one brand of tire may be just a little wider then the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 5:50am
The rim is slightly untrue and could have been welded a bit off as the tractor parts are true. The tire size is 14L x 16.1. They are awesome tires and I simply need a spacer of some kind. Thanks! Dana
                          Dana
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 6:08am
14L on a 200! Wow! Pics?
Wink
I am a Russian Bot
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 9:29am
US wheel adapters has them, standard 6 lug pattern chevy ford etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 9:33am
jegs has them also and prolly summit
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 1:31pm
Thanks y’all anyone happen to know the hub size? I know 6 hole but I’m on the road in the air and cant mic it from here☺️. Thanks! Dana
                          Dana
