allis 200 3 point creeps down
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Topic: allis 200 3 point creeps down
    Posted: 29 May 2012 at 7:58am
Bought a 3 point diskbine and it wont hold in one spot it creeps down, is ther a valve that i can check or is it in the pump.   thanks for any help.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 8:26am
Creeping down, or settling won't be in the pump, but will be in the valve stack or a bad seal, leaky hose in or on the lift rams.  Do you have any leaks around the lift cylinders?  It is almost certainly in the valve stack.  How fast does it settle?  If you lift it as high as it goes, how long till it hits the ground.  Settling is normal in most of these tractors, but I am guessing you are seeing this in minutes instead of days.
Still in use:
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 8:40am
ACs are bad at not holding up at 3ph. I have never had one too hold up completely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 9:07am
No leaks, about every 5 to 10 minutes i have to raise it back up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 10:17am
I would call that very normal for that hydraulic system and there are some that are way worse. You have a couple of options....#1.keep doing what yoiu're doing...#2. Use the position control lever on the back of the console to limit how far down it can settle. #3. Use a chain on the right hand lift arm up to an unused hole in the top link bracket to keep the settling to zero because when adjusted correctly the chain carries the weight. I'd use the chain method myself to not be using the hydraulic systems position control which will generate heat over time from the small hydraulic pump constantly trying to raise it back up.
